engine vibration over 2500 rpm's
Old Jul 26, 2007 | 06:42 PM
onegreedy's Avatar
onegreedy
Default engine vibration over 2500 rpm's
i have only had the 67 for 2 weeks now, it has a mid 80's 351 w bolted to a t5z but i noticed when i am in neutral and i rev the car i can feel a vibration, i know it can be the mounts, or even the tranny mount, but where i am worried is could it be the harmonic balancer or an internal problem. or maybe even a incorrectly balanced flywheel,
is the 289 internally balanced or is it balanced from the flywheel, and could this be my problem? sinve i believe the po used oringinal parts on the swap!
engine runs strong, no signs of trouble or weird sounds , will pull real hard to 5500+ rpm's
Old Jul 27, 2007 | 10:37 PM
onegreedy's Avatar
onegreedy
Default RE: engine vibration over 2500 rpm's
bump
Old Jul 28, 2007 | 12:51 AM
Colorado_Mustang's Avatar
Colorado_Mustang
The balance is different between the 289 and mid-80's 351. You need to get the properly weighted flywheel/damper, or tear down the engine and take it to a machine shop and have it balanced. If you continue to run the engine, you will destroy the bearings...and possibly crank.
Old Jul 28, 2007 | 10:25 PM
onegreedy's Avatar
onegreedy
thats what i was thinking
Nick Oliver
Oct 17, 2018 04:22 AM
bjdutch2005
Mar 24, 2017 03:38 AM
SSG Steggy
3.7L V6 Technical Discussions
Nov 5, 2015 03:09 PM
musnicki
Sep 23, 2015 07:11 AM
zanemoseley
Sep 6, 2015 12:58 PM
