Looking for a Carb guy
Old Jul 27, 2007 | 11:16 AM
jrstall's Avatar
jrstall
Default Looking for a Carb guy
i have a 82 gl straight 6 with a 1 brl carb, is there anything special i would have to do to put a bigger carb on it and how well would that help out with more power or such?
Old Jul 27, 2007 | 11:34 AM
67mustang302's Avatar
67mustang302
Default RE: Looking for a Carb guy
It's doubtful it'd run any better with a bigger carb, it'd prolly run worse. And get worse mileage
Old Jul 27, 2007 | 01:47 PM
mySAVIOReigns's Avatar
mySAVIOReigns
first of all, I think this might be in the wrong forum...
But I don't see how it can drive worse? More air (to a point) is better. I would consider a 2 bbl carb upgrade. Easy to do, and should be enough air. I would imagine your carb is somewhere around 180CFM - a 2bbl would likely get you to 275-280. It would need to be properly jetted and tuned, of course, but that is the same with any carb
Old Jul 27, 2007 | 02:45 PM
mat11089's Avatar
mat11089
the reason more air isnt always good is that more air pulls more fuel(if uve ever leanred about carbs) and if teh motor cannot use it all it just wastes fuel..67 is probably right about not really helping.At least for the cost.
Old Jul 27, 2007 | 03:07 PM
mySAVIOReigns
Yea, I used to study air intake and combustion design in college. But he has a 300 inline 6 - a big ol' boy.Here is a good guess as to what CFM you need. Technically, I could work it out by math, but I don't feel like it
What I'm saying though is that if you have a dinky 180CFM carb on a 300inline, it is starving for air.
jrstall, check out www.fordsix.com/forum/- they have a 300ci section.
Old Jul 27, 2007 | 10:22 PM
67mustang302
Those 300 i6's also had a tiny little peanut cam, and each cylinder is breathing through the carb in puffs, not all 6 at once. Putting a bigger carb on it will most likely reduce the fluid velocity in the venturi and weaken the fuel metering signal, resulting in poor atomization and ineffective combustion, and the poor velocity in the manifold may cause fuel to fall out of suspension as well and puddle in the manifold. There's a reason they only came with that rinky dinky 1bbl carb. That engine does 1 thing and that's make torque down low, a bigger carb will kill that torque
Old Jul 28, 2007 | 01:04 AM
mustube's Avatar
mustube
Performance wise, it probably wont help out too much, but if your ignition is in good order then it will most likely smooth out your engine and give you a little better mpg. You could have your intake milled for a direct mount or buy an adaptor and just bolt it onto the origional carb opening. Check out www.fordsix.com
Nick Oliver
Oct 17, 2018 04:22 AM
mdj89
Sep 6, 2015 11:08 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
Luke9222
Sep 4, 2015 06:46 AM
cbird1177711
Sep 3, 2015 08:43 PM
