engine assemb. problem
Old Aug 2, 2007 | 04:53 PM
eep4life's Avatar
eep4life
Default engine assemb. problem
so i have a 69 with a 302 and im trying to put all the front back together on the 302 i got the alt. back on and the crank pully. but i cant remember how to put on the power steering pump.... originally it had the ac compressor also. is there a way to mount it with out using the compressor... what is needed ect. i took it apart and cant remember how it went.....
Old Aug 2, 2007 | 07:09 PM
Scott H.'s Avatar
Scott H.
Default RE: engine assemb. problem
Old Aug 2, 2007 | 10:49 PM
eep4life's Avatar
eep4life
ok so im having some troble remembering... but is the power steering pump mounted to the ac compressor and its mount... is that why you need to switch to a non ac mount..... also... eventually i plan on adding one of those new ac units how do they mount to the motor can use the old ac mount does any one no
Old Aug 2, 2007 | 11:09 PM
66GTKFB's Avatar
66GTKFB
The non-airconditioning power steering mounting bracket is a non-existant item. The simple answer is Ford used a spacer on the pivot stud at the head, p/n C7SZ-3D600-A described as 7/16 ID, 1.0 OD and 9/16 inch thick.
Jim
djbigskrilla
Sep 20, 2022 01:04 AM
ShaneB26154
35
Mar 4, 2021 04:05 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
HIS S-197
Aug 10, 2015 05:47 PM
Pain.
Aug 7, 2015 10:48 PM
