engine wont start
Old Aug 5, 2007 | 03:34 PM
66MuStAnG4sho's Avatar
66MuStAnG4sho
Default engine wont start
I have a 66 Mustang with a 302-2V engine. I just bought a brand new Starter, starter solenoid, and starter switch and when i go to turn on the car, you can hear the starter working but it does not turn the engine over and it won't start the car. Also, sometimes when i turn off the car, the starter stays running and will only turn off after i disconnect the battery. Any body got any suggestions on how to fix this?
Old Aug 5, 2007 | 03:37 PM
DCStang65's Avatar
DCStang65
Default RE: engine wont start
Hey,
I posted a similar problem. Was at the store and my '65 Coupe wouldn't start. The solenoid was making a wonderful grinding noise, but no juice was getting to the starter. Since then, I've replaced the solenoid, but same issue. Now, the battery is dead.
Check out my post, "What Friggin' Next?...The Starter." Lots of good ideas in there from the Forum.
Good luck.
Old Aug 5, 2007 | 04:03 PM
Soaring's Avatar
Soaring
I ♥ Acer
If your starter continues to run after the engine is running and the ignition key has been taken off the start position, my first suspicion is that the bendix spring in your starter is not disengaging as it should . Take the starter out and have it checked at a parts store.
Old Aug 5, 2007 | 04:22 PM
66MuStAnG4sho
It is a brand new starter i bought only three days ago. I have read the other post about this, but my problem seems all electrical, i think. The battery is fine, the alternator is fine, it seems the starter bendix is not engaging the flywheel to turn the engine over. However, i inspected both the bendix and flywheel teeth and they seem fine. My uncle sez he has seen flywheels with worse teeth that work.
Old Aug 5, 2007 | 06:31 PM
67coupe's Avatar
67coupe
If the voltage is low the amp draw will go high enough to weld the solenoid contacts. Then the starter keeps running also. I had a bad cable causing a low voltage to the starter. Do a volt drop test.
Place the positive end of your meter on the battery and the negative on the starter terminal. When you crank the engine whatever you read on the meter is what you are losing. It should read close to zero. If you get a high reading keep trying the leads on different legs of the circuit until you isolatethe problem section.
Old Aug 5, 2007 | 06:47 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: 66MuStAnG4sho
OK, there are a couple of things to think about Whenever I go to get a new starter, I have to order/get one for an automatic even though I have a manual tranny. Somehow back in the day, the computer geeks put in the wrong numbers, so that manual tranny guys have to get a numbers matching starter (acccording to their computer) for an automatic. The neck on the starter is different and the nose is too. If you have the wrong starter on there it will not engage the flywheel and if it does, it will chew off the very tip of the flywheel gear and the gear on the starter will be chewed away.
Old Aug 6, 2007 | 06:54 AM
73 Sportroof's Avatar
73 Sportroof
I had the same problem with my '84 F-150. It has a 351W HO and it takes a different starter. I couldn't figure out what was wrong, every parts store said it took the same starter. I finaly took it to my mechanic and he figured it out. He put the right starter on along with a new flex plate. No problems since.
Old Aug 8, 2007 | 02:18 PM
66MuStAnG4sho
Thanks guys, i ended up takin her to the mechanic. He told me it was the starter and starter solenoid. both of which are brand new. i guess no more cheap parts from autozone, haha. I think i'll probably have to get a new starter switch too, because i think i fried the old one when i tried running the car. sad day...I didnt even think to tell the place i got the starter from that i dont have an original engine in my car. Guess thats my young age stupidity.
djbigskrilla
Sep 20, 2022 01:04 AM
ShaneB26154
35
Mar 4, 2021 04:05 AM
Spiral534
Oct 6, 2015 04:31 PM
KEM Motorworks
Aug 14, 2015 10:13 PM
