Heater core leaking
Old Aug 6, 2007 | 12:08 PM
jspagna1's Avatar
jspagna1
Default Heater core leaking
My heater core started leaking. It leaked a few years ago and stopped, now it just pees a little. Is it a PIA to replace and what will it cost? Thanks in advance.
Old Aug 6, 2007 | 12:31 PM
nassaubayman's Avatar
nassaubayman
Default RE: Heater core leaking
A heater core for a 65/66 without A/C is only 22.95 at Mustangs Unlimited.
http://www.mustangsunlimited.com/ite...p?T1=FM9022+01
You have to disconnect the two heater hoses, then remove the heater box. Instructions are in the Shop Manual (I don't have mine here at work). A non-A/Cis easier, but still no picnic.
Old Aug 6, 2007 | 01:37 PM
66GTKFB's Avatar
66GTKFB
It get a little more complicated than just removal of hoses. In most cases the hoses have 'molded' their ends to the fittings on the engine and may have to be cut off - now you need new hoses. When they come off, coolant will pour out - fact. The solution is to drain the radiatoror cut one hose long enough to make a loop back to the other fillting. You can still sdive the car this way - after putting the coolant back. Next, the clamps - they're old and may fall apart. Those are easy to get at a local auto parts store - or you can get the tower type when you order the core. When you take apart the heater box, you will find it has a lot of leaves and other junk that came in thru the cowl. Also, there are foam gaskets and seals in the box - you need the heater rebuild kit. Consider a new plastic plenum as well.
To remove:
1. Disconnect hoses.
2. Disconnect the two wires to the blower.
3. Remove passengers seat. Remove the three control cables from the core and defroster.
4. In the upper right corner, there is a long sheet metal screw that needs to come out. It requires a 3/8 hex socket on a long extension.
5. Remove the four stamped nuts in the engine compartment around the blower.
6. Give the blower a push and pull the heater out in the passengers area. The hoses will come thru last.
To replace core:
1. Remove hoses.
2. Remove defroster plenum.
3. Using two screwdrivers, one one each side, pry apart the 11 clips that keep the heater box together.
4. The box will come apart with a little prying.
5. Scrape old gaskets and foam off.
6. Scrap, wire brush or sand metal and paint black.
7. Using 3M spray adhesive, install new seals and foam. There are instructions as part of the seal kit.
8. Reassemble box and plenum.
9. Loop the uncut new hose thru the two holes in the firewall and attach to core with clamps. You can cut to length after the heater is installed with out screwing up on the lengths.
10. Re-install box, cables, wires etc and attach hoses.
Jim
(What did I miss?)
Old Aug 6, 2007 | 01:51 PM
Soaring's Avatar
Soaring
I ♥ Acer
(What did I miss?)
Top off the rad with coolant, start the car and test the new heater box and hoses for leaks.
Old Aug 6, 2007 | 02:01 PM
66GTKFB's Avatar
66GTKFB
Why? If you do a good job you will have no leaks.
Jim
Old Aug 6, 2007 | 02:14 PM
Soaring's Avatar
Soaring
I ♥ Acer
It wouldn't be the first time a pin hole was punched into a heater core during shipment.
Old Aug 6, 2007 | 02:26 PM
66GTKFB's Avatar
66GTKFB
We need a 'pin-hole' awareness day, say next February 30. It should include radiators, heaters, all hoses and tires. Engines will have to get their own day.
Jim
Old Aug 6, 2007 | 02:34 PM
Soaring's Avatar
Soaring
I ♥ Acer
February 30 is 'save the rooster day' so you will need to pick another day. Say February 31st.
Old Aug 6, 2007 | 02:45 PM
66GTKFB's Avatar
66GTKFB
Is the 'rooster' day exclusive to Texas? I got a PM with a question - do we include pinheads?
Jim
Old Aug 6, 2007 | 02:51 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, let's include anything with a pin in the name. Pinwheels, pinballs, rack and pinion.................
