engine hoist rental
Old Aug 8, 2007 | 12:24 PM
66mjchiara's Avatar
66mjchiara
Default engine hoist rental
so where can i rent an engine hoist ive called around and nobody has any knowledge on where to rent one.
Old Aug 8, 2007 | 12:30 PM
65StangFB's Avatar
65StangFB
Default RE: engine hoist rental
I wish I could help on the rental, but consider this. I starting looking around my location to see how much some were and they started at $125 used in the paper. News are around $150-$200.
Pep Boys has one right now after rebate it is $99. I decided to buy one and if I dont want to keep it I can sell it in the local paper and atleast break even.
Old Aug 8, 2007 | 12:32 PM
66_grn_fstbk's Avatar
66_grn_fstbk
Instead of renting one, check craigslist, by a used one with a leveler. Then when you are done, put it back on craigslist and I bet it will be cheaper than renting one for the amount of time you will need it.
In the san diego area, there is usually one or two week that popup. Perhaps similar in your neck-o-d-woods
cheers
csr_sd
backsplatter's Avatar
backsplatter
You might want to include what area you are looking in.
Old Aug 8, 2007 | 12:49 PM
66mjchiara's Avatar
66mjchiara
im looking in temecula, ca its about 30min north of san diego
Old Aug 8, 2007 | 01:45 PM
jlg2002's Avatar
jlg2002
try united rentals.
Old Aug 8, 2007 | 10:38 PM
06triplevalve's Avatar
06triplevalve
66 Green Fastback RULES!
I have needed a hoist and have scoured eBay for one, to no avail in my pricerange. I even found one guy 4 miles from me that refused to let me pick it up...he wanted ONE HUNDRED THIRTY DOLLARS to ship it 4 miles. Sheesh!
So, when I read this thread earlier today, I was so happy you mentioned Craigslist! I hadn't thought of that. Well, I found one 30 miles from me, it even came with a engine leveler, for (drumroll) $25 BUCKS! YIPPIE FOR ME!
So, thanks for the suggestion. I plan on using it and then passing on the excellent deal to someone else. No reason to not make someone elses day!
Roy
Old Aug 9, 2007 | 12:37 AM
Sean W.'s Avatar
Sean W.
do it the red neck way... use some pullys and a tree.....
or....i used a fork lift to pull mine...
Old Aug 9, 2007 | 01:16 AM
andrewmp6's Avatar
andrewmp6
sean seen a car done like that tree broke and crushed in the roof of the car. have you tried http://www.harborfreight.com/ or pull out your phone book and look under tool rental call everyone and ask how much.
Old Aug 9, 2007 | 01:23 AM
Sean W.'s Avatar
Sean W.
ORIGINAL: andrewmp6
......... you could tell a hell of a story ehh
