Front suspension question!!!
Old Aug 9, 2007 | 04:00 PM
JohnCalvin's Avatar
JohnCalvin
Default Front suspension question!!!
How can i remove the stock springs with out a spring compressor? The spring compressor i rented goes on the inside of the spring... but how in theworld do i get it on the inside? Not a single one of the autozone guys had a clue. So i rented it anyways to see what i can do... any help please???? Can i just use a jack to compress them then throw on some webbing or somehting to keep it compressed? Or is that just asking for a trip to the emergency room. I'm replacing them with some 620 1" drop coils.
Old Aug 9, 2007 | 04:14 PM
dodgestang's Avatar
dodgestang
Default RE: Front suspension question!!!
You have to remove the shock tower cap, then the shock, and insert the spring compressor from the top. It requires you to open the hood.
Old Aug 9, 2007 | 04:24 PM
JohnCalvin's Avatar
JohnCalvin
currently it doesn't have a hood! I just built an engine and swapped it in... then i was putting on the new export brace and took the shock tower caps already... so thanks, i'll pull out the shocks and drop the compressors in there!
Old Aug 9, 2007 | 06:24 PM
mikethebike's Avatar
mikethebike
Tip.....compress the suspension with a jack under the brake drum/disc and you won't need to work the compressor aganist the spring.
Old Aug 9, 2007 | 06:30 PM
bluovalguy's Avatar
bluovalguy
ORIGINAL: JohnCalvin
Well then that should make it pretty easy
Old Aug 9, 2007 | 06:52 PM
coda618's Avatar
coda618
The fact that not a single autozone guy had a clue is really scary. Support your local mom and pop parts houses and businesses.......before Walmart takes over the world.Oh yeah, and buy USA!!!
rant off.
Old Aug 9, 2007 | 06:55 PM
66GTKFB's Avatar
66GTKFB
Go to https://mustangforums.com/m_3638446/tm.htmand look at spring compressors that won't kill you.
Jim
Old Aug 9, 2007 | 10:04 PM
htwheelz67's Avatar
htwheelz67
I thought autozone guys were geniouses..........make sure the compressor is as striaght as possible while tightening (rotate it) or it will bind against the shock tower, watch how much threads are coming out the bottm as it can hit the spring perch as well. put it on with the car jacked up and slightly tighten, then let the car down a bit and tighten more let the cars weight help you then jack it up again slowly and tighten if needed and remove the spring carefully.
when removong the compressor stand to the side of the spring and hold it with your foot and make sure there is enough threads left to completly remove tension of the spring.
if your doing the shelby drop and 620s you wont usually need the compressor to put them back in they will go in with out it.
Old Aug 9, 2007 | 10:13 PM
htwheelz67's Avatar
htwheelz67
heres a trick to remove springs with out a compressor, if you are going to throw them away after doing this........after removing the shock,remove or loosen the sway bar end links, heat the spring in the middle red hot with an acetylene torch jump up and down on the bumper, do it a couple times and the springs will shorten enough to remove when the car is jacked up. Back when I was a kid I lowered my car that way but it takes the temper out of the spring........yea I know its a crude dumb way to do it but no compresser needed................
Old Aug 9, 2007 | 11:02 PM
Daze's Avatar
Daze
go with the bolt in tipe. Here is a picture of the one I made and below that is a story of why I made it
the fallowing is an excerpt from my web page on how to build one like the one pictured
Spring Compressors 101, Why use a bolt-in type?
- When removing a coil spring, it is required to compress the spring to free it from its designed location. Failure to safely deal with compressing the spring can result in serious injury or even death. There are three main ways to compress a coil spring to remove it: external claw type spring compressor, internal claw type spring compressor or a bolt-in type spring compressor.
- An external claw type spring compressor consists of two separate pieces that clamp onto the outside of the coil spring. As the nuts on the two pieces are tightened down, the spring is compressed. There are three main issues with this type of compressor. First, both sides need to be tightened an equal amount and, since each piece has its own tightening nut, this is easier said than done. Second, this type of compressor REQUIRES that the two separate pieces be opposite of each other. Unfortunately, the shock towers of a classic Ford do not allow the two pieces to be positioned completely opposite of each other, which creates an unstably compressed spring. Third, the claws of the compressor are held to the spring by tension from the compressed spring. If the claws slip, the spring can decompress violently. Many chose to use this type of compressor because they are inexpensive and can be purchased for less than $30.00.
- The second type of claw spring compressor is an internal unit, which has four claws (two at the top and two at the bottom) that grab an upper and a lower coil of the spring. One tightening nut pulls the two sets of claws closer together and compresses the spring. This compressor is much better for a Mustang than the above mentioned external claw type, however, it is still not the best option. There are two main problems with this type of system. First, often times on a classic Ford, a 3 to 4 inch spacer (usually a piece of pipe) is required to be positioned between the upper claw assembly and the tightening head to keep the compressor from bottoming out in the UCA. Secondly, as with the external claw type, the tension of the compressed spring is all that holds the compressor in place and, as before, if those claws slip, the spring can decompress violently.
- It was an internal claw type compressor that sent me to the emergency room in June of 2005. After already removing the passenger’s side spring, I was working on the driver’s side assembly, had compressed the spring and was in the process of removing it when the compressor slipped, the spring decompressed and pinned my right hand by the three middle fingers, palm side up, between the bottom of the coil spring and the spring perch. Engaging this type of compressor requires using two hands and, of course, I was alone, the garage door was down, my cell phone was on the passenger’s side fender out of reach and most of my tools, at least any that could have been effective in freeing my hand, were on the floor next to the passenger’s side where I had already pulled the suspension apart. All I had within arms reach was the ½” box wrench (no more than 6” long) that I had just used to remove the shock. I jammed the wrench in between the spring and the perch and was able to pry the spring up enough to get the finger next to my pinkie free. I then pried on the opposite side and got my index finger free. To get my middle finger out, I pried again with the wrench and pulled as hard as I could with the trapped arm and got my hand out. To make a long story short, I still have all my fingers and they still work, however, I occasionally feel some stiffness in the middle finger joints. I was lucky!!!!! Needless to say, it is my personal mission to convince everyone to use a bolt-in type compressor.
- The third type of spring compressor is the previously mentioned bolt-in type compressor. This compressor bolts to the spring perch and the top of the shock tower, just like a shock. Once the spring has been compressed, there is no way for it to come loose unless you intentionally decompress the compressor. The “down side” to this type of compressor is that in order to completely remove the spring, the UCA needs to be removed to get the spring out. This adds about 15 minutes to the task of changing springs, however, that 15 minutes is well worth the improved safety factor.
