how to remove seatbelts
Old Aug 11, 2007 | 12:04 AM
69stangcoupe's Avatar
69stangcoupe
Default how to remove seatbelts
so im taking out my carpet so i can get my floorpans done. and i need to take out the seatbelts but they have a weird type of bolt holding them down. its like a phillips head but its a star. how do i get this thing out without stripping them? ive tried looking for this special kind of tool but cant find it.
Old Aug 11, 2007 | 12:26 AM
05SDI's Avatar
05SDI
Default RE: how to remove seatbelts
You need a T50 Torx that fits on a ratchet. You can pick up a 'cheap' set for under $30. But the good ones are much more.... As with most tools you get what you pay for so how much will you be using them....
Old Aug 11, 2007 | 12:30 AM
connor90's Avatar
connor90
you can buy those ratchets individualy at Sears
Old Aug 11, 2007 | 12:37 AM
4reboy's Avatar
4reboy
You can get them at harbor freight for much cheaper. Those are the only bolts like them on the car, so don't worry about cheapness. Just get watever.
Old Aug 11, 2007 | 12:40 AM
69stangcoupe
this is the only thing that i can think of that i would use them for. can i rent them at napa maybe?
if not ill just go to sears and get em
EDIT:: oh and would you know what size the bolts on the seatbelts is?
Old Aug 11, 2007 | 01:40 AM
05SDI's Avatar
05SDI
If you are asking what size 'wrench' you need I answered this in my first post. Torx areidentified in sizewith a T followed by a number. This number has NO reference toan actual measurment (IMHO)other than bigger number is larger in size. In the pic above they range from largest on the left to smallest. T50, T45, T40, T30, T27, T25, T20, T15, T10, T9. The size torx you need for your seat belt bolts is a T50. Hope that is what you were asking!
Old Aug 11, 2007 | 06:23 AM
Oxnard Montalvo's Avatar
Oxnard Montalvo
Tools are good.
A lot of newer cars use torx head bolts of varying sizes. Buying a cheap set now for the one you need will pay off in the long run.
Good luck, soak them with penetrating oil and give the head a solid whack with a hammer before you try to unbolt them.
Old Aug 11, 2007 | 09:50 AM
69stangcoupe
thanks a lot guys
Old Aug 11, 2007 | 01:01 PM
gothand's Avatar
gothand
If you had a late model Jeep Wrangler, you'd already own a good quality set. This tool is one instance where a cheapie may not get the job done on stubborn bolts. Make certain to use the correct size bit when removing a bolt. Often times, a slightly smaller bit will fit and appear to work but will more easily strip the bolt.
Old Aug 11, 2007 | 03:24 PM
Waffles's Avatar
Waffles
From: Detroit; where the weak are killed and eaten.
harbor freight, gross.
I'll stick with my mac, matco, snap on, and craftsman. thank you.
