undercoating question
Old Aug 12, 2007 | 07:23 PM
70coupe's Avatar
70coupe
Default undercoating question
So my Tranny that i just had rebuilt in january went out again so i have the engine and tranny out right now and i want to redo the undercoating and engine bay as far as the undercoating whats the best way to go about doing it? do i need to take the rear end off or can i leave it on whats the best way so that it will look good
Old Aug 12, 2007 | 07:46 PM
scuf23's Avatar
scuf23
Default RE: undercoating question
I did my undercoating with the rear suspension in place and the rear axle in place - I think the final result looks pretty good - you can check it out on a post I put up yesterday about which materials to use to do the undercoating (I like the eastwood products) - let me know what you think ...
Old Aug 12, 2007 | 07:59 PM
70coupe's Avatar
70coupe
did you coat your rear end as well or cover it or what?
Old Aug 12, 2007 | 08:05 PM
scuf23's Avatar
scuf23
Yes I did the rear axle as well
Check out the pictures on that thread https://mustangforums.com/m_3686039/tm.htm
Old Aug 12, 2007 | 08:10 PM
70coupe's Avatar
70coupe
sweet thanks a lot man...one more question though does the rust converter work well or should it be sand blasted or what i mean there is only surface rust nothing major so with the rust converter work ok?
Old Aug 12, 2007 | 08:12 PM
scuf23's Avatar
scuf23
I did not have rust, so I used rust encapsulator as a primer to protect from any potential future rust, than applied a topcoat- I did not sandblast, I used a metal wire wheel and a lot of patience ! I am doing the same thing on my fastback but I think I will get the entire car blasted ... good luck with your project
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
