Engine trouble under load: low power, surging\bogging
Old Aug 13, 2007 | 10:51 PM
Ziggysan's Avatar
Ziggysan
Default Engine trouble under load: low power, surging\bogging
Hey y'all -
1966 289 3spd
Rebuilt the engine and replaced the seals throughout. I've got the timing more or less set (matched it to a properly timed '82 5.0 289) and it actually moves now, as well as running consistently. The idle sounds a bit high to me still.
I'm using a professionally rebuilt 2bbl stock carburetor (Autolite 2100?)
However, the major problem is that the engine is bogging and feels like its surging when I begin to put it under load and is not developing any power. It feels like it is going to stall once I shift into second (haven't been able to get up to speed for 3rd yet) and I feel like its just barely above a coast.
I also need to know where the vacuum advance line should be connected (mine is metal tubing) and where I should connect the line coming out of the thermostatic choke.
Forgive me if I'm not properly describing the issues, but I'm not as familiar with the terms as I'd like.
Thanks in advance!
Old Aug 13, 2007 | 10:56 PM
JMD's Avatar
JMD
Default RE: Engine trouble under load: low power, surging\bogging
Just a shot in the dark, but if I were you I would check my points first (if I still had points), then I would replace the ignition coil.... if it turns out that the coil is good, you will still have a spare for later....
Barring these issues, I would verify that you don't have vacuum leaks, I was thinking this because of your high idle compounded by your other issues.
Old Aug 13, 2007 | 11:32 PM
66GTKFB's Avatar
66GTKFB
The vacuum advance from the distributor goes to the lower right hand side base of the carburetor into a threaded hole.
There are two steel tubes going out of and into the choke area and both go to the right hand exhaust manifold at the rear to be heated. The cool air to the manifold comes from a short cast in fitting in the right hand upper part of the carburetor, transitions to a piece of rubber hose about 4 inches long, transitions to the tubing and goes to a hole on the under side of the heating chamber. The second tube comes from the top of the manifold wrapped in protective hi-temp cloth to a threaded fitting on the choke. There is a clip that holds them together.
I recomend that both the vacuum tube and the choke tubes be new.
Jim
Old Aug 14, 2007 | 01:29 AM
Ziggysan's Avatar
Ziggysan
The ignition coil is new and the distributor was functioning fine prior to the rebuild. The engine had begun dying before the strip down, particulary early in travel while moving downhill. However, I believe the problem that required the rebuild to have been the 1.5" slack in the timing chain and the five inch crack in the timing chain cover.
djbigskrilla
Sep 20, 2022 01:04 AM
Diode Dynamics
28
May 26, 2022 12:02 PM
ShaneB26154
35
Mar 4, 2021 04:05 AM
msavoia23
12
Jul 7, 2018 12:08 PM
movielover40
Aug 27, 2015 10:13 PM
