*URGENT*Difference between 'concourse' and std. export brace??
Old Aug 15, 2007 | 01:18 AM
350kmileFord's Avatar
350kmileFord
Default *URGENT*Difference between 'concourse' and std. export brace??
http://www.mustangsplus.com/Merchant...ry_Code=export
I tried to look it up. I got two answers:
1.They are stronger
2.They are oem
So which is it? Judging by the picture, it is obviously not oem.
I have an order ready on Mustangs Plus and I am waiting for the right answer so that I can submit!
Old Aug 15, 2007 | 01:58 AM
Aussie66Fastback's Avatar
Aussie66Fastback
Default RE: Difference between 'concourse' and std export brace??
price
there were 2 different kinds of export brace that i am aware of.
one bolted to brackets that were in turn welded to the outside of the shock tower. these were **** weak.
the other is per those pics where the firewall piece is as one and they bolt to the top of the shock tower.these are much stronger.
between concourse and standard from MP did they offer an explanation?
Old Aug 15, 2007 | 01:59 AM
350kmileFord
No they do not; thus this topic.
Old Aug 15, 2007 | 02:09 AM
Aussie66Fastback
i will be interested to hear the result
Old Aug 15, 2007 | 03:48 AM
350kmileFord
I think it may mean oem/stock looking pieces. I just placed the order, with the standard brace.
http://img513.imageshack.us/img513/8...gparts2iw8.png
Note shipping charge <_<
Old Aug 15, 2007 | 04:37 AM
andrewmp6's Avatar
andrewmp6
concourse is a huge pricey car show ever heard of pebble beach thats a concourse car show. this is the most **** car show there is they look over everything car has to be just like it was when it was built. save your money buy the cheap one
Old Aug 15, 2007 | 04:51 AM
350kmileFord
More evidence that it means original. It's a 'most stock' car show.
Old Aug 15, 2007 | 07:35 AM
bluovalguy's Avatar
bluovalguy
ORIGINAL: Aussie66Fastback
price
That is whats on my car, and I thought it was some ghetto work that the PO did. I am gonna replace it anyway.
Old Aug 15, 2007 | 10:40 AM
66GTKFB's Avatar
66GTKFB
The difference is in the thickness of the steel used and the way it's formed. The more expensive one is formed to the original Ford specifications including the material thickness. The cheap one is exactly that - cheap. As to concourse acceptability, only cars exported to Europe were equipped with this type of brace from the factory, e.g. DSO's of 9x (for those that do not understand this type of notation, 'x' means any number between 0 and 9), so at a full blown concourse car show, you would loose points for having one. This did not apply to Shelbys which had a different mounting hole spacing at the firewall.
Jim
Old Aug 15, 2007 | 11:11 AM
dodgestang's Avatar
dodgestang
Well.....since the export brace was names the export brace because it was required on cars that were 'exported' it is hard to find an example of a stock one in the states other than the ones Shelby used on his cars. However the difference between the two links above is price and that warm fuzzy feeling guys get when they pull their micrometer out and say things like "The original OEM Ford export braced in cars exported to Europe was xxx.xxx thick stamped steel, this one you have is obviously a lower quality china stamping"
darnit....that's what happens when you start making a post and walk away from the PC for 2 hours. Someone else says the same thing.
