HP EST.
Old Aug 15, 2007 | 03:24 AM
eep4life's Avatar
eep4life
Default HP EST.
ok so i i finially think i have all the specs and i was woundering if some one could give me an est. on how much HP ill be making...
i have
302. bored over 40
stock heads, ported
edlbrock, performer intake
headers
hei distributor
holley 600 cfm 4 brl carb
new valves, springs, lifters
and for cam, since i dont know what the specs mean ill just put them on here the way its written on the box
cam lift valve lift lobe ctrs. lash hot
int. exh int. exh. int. exh. int. exh
.280 .295 .448 .472 107 117 hyd
adv. dur. .050 dur.
270int. 280exh. 204int. 214exh.
adv. timing .050 timing
btc abc bbc atc btc abc bbc atc
27 63 76 24 -5 29 44 -10
Old Aug 15, 2007 | 07:23 AM
muggsy's Avatar
muggsy
Default RE: HP EST.
these guesses are always fun...i dunno....say....275ish at the crank
Old Aug 15, 2007 | 08:34 AM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: HP EST.
I came up with 255 at the flywheel.
Old Aug 15, 2007 | 09:23 AM
my77stang's Avatar
my77stang
Default RE: HP EST.
i was thinking 250-300, so yeah... there ya go[8D]
Old Aug 15, 2007 | 10:04 AM
Smothers's Avatar
Smothers
Default RE: HP EST.
268 1/2 hp at flywheel.
Old Aug 15, 2007 | 10:07 AM
john721's Avatar
john721
Default RE: HP EST.
my turn? 289...., .030 over, 650 double pumper holley, hyd. roller comp cam "thumper" series cam, hyd. roller rockers, 165 AFR aluminum heads, wieand aluminum intake, electronic iginition, ceramic coated headers, x-pipe 2 1/2" exhaust....HP? ....love to hear your thoughts...
Old Aug 15, 2007 | 11:06 AM
dodgestang's Avatar
dodgestang
Default RE: HP EST.
165 at the back tire and 200 at the back tire respectively.
Old Aug 15, 2007 | 11:09 AM
eep4life's Avatar
eep4life
Default RE: HP EST.
ok sounds good.... so two more things....... one what would has more get up.... my 302 that we have been talking about or my 289... all stock ecept it has a holley intake and a holley 650 cfm carb...... and also for my 302 what sould be my next investment in the motor as far as power goes
Old Aug 15, 2007 | 12:30 PM
JMD's Avatar
JMD
Default RE: HP EST.
IMO, both of those should be about 1 HP to the CI at the flywheel,,, first example because of the pretty damn warm cam, and the 2nd example because of the aftermarket heads....Some 57 chevys claimed 1 HP to the CI,,,, I don't think either example here is substandard to this comparison.
<<answering OPs first question and John721s question.... >>
Old Aug 15, 2007 | 01:12 PM
john721's Avatar
john721
Default RE: HP EST.
Thx JMD....So I should hope for somewhere around 290-300 hp?
