Carb Value Question
Old Aug 19, 2007 | 03:31 PM
DCStang65's Avatar
DCStang65
Default Carb Value Question
Should the butterfly valve on the carbuerator move at all when the engine is revved. Know nothing about this and my 65 Coupe has been idling and running rough. Took off the air filter to check the carb (per a tip someone else on the forum gave me). Thevalve does not move when I gas it. Thoughts?
Old Aug 19, 2007 | 03:48 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Carb Value Question
The butterfly is related to your choking system. If the engine is cold, and you depress the gas pedal a few times, the butterly should be completely closed. If it isn't, then your choke mechanism is toast. When the engine gets totally warmed up, the butterfly will stay open all the way if it is set up correctly. Now, you may be talking about your secondaries if you have a four barrel carb. So, what carburetor do you have.
Old Aug 19, 2007 | 03:51 PM
DCStang65's Avatar
DCStang65
It's a four barrel. Not sure of the make. I started it today after about three days of sitting. Fired right up. Drove OK.
Old Aug 19, 2007 | 04:34 PM
Colorado_Mustang's Avatar
Colorado_Mustang
If you're talking about the choke plate (on top of the carb), it should be vertical when warmed up. If you're talking about the secondary throttle plates, you won't be able to make them move unless you have a mechanical secondary carb. You actually have to drive a vacuum 4v to get the secondaries to open.
Old Aug 19, 2007 | 04:40 PM
DCStang65's Avatar
DCStang65
That answers it. It is the choke plate, and it is up. So, have to look for another cause to the problem...
Old Aug 19, 2007 | 05:11 PM
67mustang302's Avatar
67mustang302
Might be trash in the carb, might need a tuning. Has the fuel filter been replaced?
Old Aug 19, 2007 | 05:19 PM
DCStang65's Avatar
DCStang65
Have had the carb adjusted twice. When I got it, the carb was running really rich and idling way too high. Fuel filter was recently replaced. Here's the skinny: Fired her up a week ago and made it about a block from my house when it died. Started up fine, but would continue to kill if I gave it any measurable amount of gas. And it idled like someone was jumping up and down on the hood. Nice...
GimpyHSHS
19
Dec 19, 2023 01:12 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
UrS4
Sep 30, 2015 10:13 AM
treesloth
Sep 28, 2015 07:03 AM
