sway bar frame bushing install
Old Aug 19, 2007 | 10:56 PM
plcdude's Avatar
plcdude
Default sway bar frame bushing install
Hello all,
I have new Poly sway bar frame bushings. However, I am unsure as to how to install them over the ends of the sway bar. The old rubber bushings just squished over the ends. However, there is no way to squish the Poly ones over the ends.
So how do you install Poly sway bar frame bushings?
Old Aug 19, 2007 | 11:14 PM
Jakaru's Avatar
Jakaru
Default RE: sway bar frame bushing install
If they were like mine you have a new bushing inside a brass half circle? take the bushing out of the brass and see if the bushing is cut in half. If it is spread the bushing and slide it over the sway bar in the correct place and then slide the brass fitting back over it. If yours does not have a slit then I would suggest some kind of lubricant to help slide the bushing over the end of the sway but that doesn't sound like much fun.
Old Aug 19, 2007 | 11:18 PM
plcdude's Avatar
plcdude
The ones I have are not cut. The only way I can see to get them on is to cut them.
Old Aug 19, 2007 | 11:26 PM
66GTKFB's Avatar
66GTKFB
Set the bushing out in the hot sun (take advantage of Global Warming before winter sets in) for 30 minutes or so, apply some liquid dish soap to the sway bar, and slide the bushing on. Do it as quick as you can.
Jim
Old Aug 19, 2007 | 11:32 PM
plcdude's Avatar
plcdude
I did not think about warming them up. Great idea. Thanks for the tip.
Old Aug 20, 2007 | 12:34 AM
paddy187's Avatar
paddy187
if the sun is toweak steal your girlfriends/wife hair dryer and do as jim says.
Old Aug 20, 2007 | 04:07 AM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: paddy187
I remember having a hair dryer myself back in the hippie days.
Old Aug 20, 2007 | 11:14 PM
boogerschnot's Avatar
boogerschnot
ORIGINAL: Soaring
ORIGINAL: paddy187
LOL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!![sm=interesting.gif]
Old Aug 21, 2007 | 04:40 AM
baddog671's Avatar
baddog671
If your sway bar looks anything like mine, forcing them over the end wont be such a smart idea. On mine the diameter of the bar is alot wider at the ends than anywhere elso. So, squishing them over is going to strecth out the bushing.
Just make a cut through the bushing and pop it over onto the bar.
Old Aug 21, 2007 | 09:03 AM
coda618's Avatar
coda618
Tip I came accross to help prevent squeeking is to wrap some teflon tap around the bar where the bushings will sit. You know, the white tape used to seal threads for plumbing.
