Trouble Starting Engine in '65 GT
Old Aug 22, 2007 | 12:15 PM
RobbieG.'s Avatar
RobbieG.
Default RE: Trouble Starting Engine in '65 GT
Did you clean the tank before you started driving it again? Everything could be pluged up too. There might be gas in the filter but none getting thru.
Old Aug 22, 2007 | 12:30 PM
fiegland's Avatar
fiegland
The degree marks are on the harmonic balancer but are very hard to see on old or dirty balancers. I had to crawl under the car and have the engine bumped a few times to be able to see them. Then I had to use white paint to remark them so that I could see them with the timing light. I would start with rebuilding the carb. A 10 year old carb just sitting will have dried out gaskets and o-rings.
Larry.
Old Aug 22, 2007 | 02:17 PM
jlg2002's Avatar
jlg2002
is that the original gas in it you're trying to run?
Old Aug 22, 2007 | 10:45 PM
1971 Coupe's Avatar
1971 Coupe
You say your getting spark, but how much? if its just a little, you should take off your distributor cap and try to turn it over, if the rotor does not spin then your down on your cam probably snaped, but if it does spin your problem is porbably carb related.
Old Aug 23, 2007 | 12:05 AM
67mustang302's Avatar
67mustang302
Heh, this is why OBDII cars are kinda nice.....just ask the Star Trek computer what's wrong [8D]
Well, not quite that easy.....
djbigskrilla
Sep 20, 2022 01:04 AM
ShaneB26154
35
Mar 4, 2021 04:05 AM
msavoia23
12
Jul 7, 2018 12:08 PM
KEM Motorworks
Aug 14, 2015 10:13 PM
