need help finding these parts
I need this parts for a 67 mustang.
1. Powering Steering Pumps
2. 2 Outer Tirods
3. Front Wheel Bushings (in & out)
Can you guys help me look for those please?
Thanks,
Christian
2. 2 Outer Tirods
Thanks,
Christian
yah i probably am. I'll just tell them that i want a power steering pump and front wheel bushings (in and out) for a 67 mustang. they should have the parts right?
When you say front wheel bushings, do you mean bearings? If so, get inners, outers and seals. The should also come with the new races. You should absolutely change them when using new bearings. As for where to buy, any local auto parts store should have them in stock. Tie rod ends to. For the pump, as said, NPD or other specialty mustang parts place should be able to hook you up.
Oh, and don't forget to check you muffler bearings while you are at it.
Good luck.
Good luck.
Do you mean inner and outer bearings or seals? The bearings are inside the rotors and the seals keep crap from getting inside the bearing grease. These are the only two things that come in "inner and outter"..
