speedometer goes nuts
Old Aug 24, 2007 | 05:29 PM
Vikefan88's Avatar
Vikefan88
Default speedometer goes nuts
hey all. i have a 65 mustang. the speedometer is original and when im driving and givin it gas ... the speedometer moves up and then the needle juss goes crazy up and down like if its loose or something.. like up to 20 mph it kinda accuarate, then aftet hat it goes nuts ....any suggestions?
Old Aug 24, 2007 | 05:34 PM
coda618's Avatar
coda618
Default RE: speedometer goes nuts
My guess would be the drive gear at the end of the speedo cable where it inserts into the trani. The gear teeth are prob worn. Its a cheap part to replace and most vendors have them. Good luck.
Old Aug 24, 2007 | 05:36 PM
doc540's Avatar
doc540
I got the same problem with a new gear drive at the trans end of the cable.
and it's intermittent to complicate matter.
My guess is it's the speedo itself in the gauge cluster.
Old Aug 24, 2007 | 05:43 PM
Vikefan88's Avatar
Vikefan88
if i get underneath the car, where exactly can i find that cable?
Old Aug 24, 2007 | 05:46 PM
cprstreetmachines's Avatar
cprstreetmachines
It will be on the passenger side right by the trans mount. Pull it out, and pull the clip off and spin the cable on a drill. This will tell you if it;s the gear, or cable. Everytime I've done one, it's the cable.
Old Aug 24, 2007 | 05:51 PM
JMD's Avatar
JMD
Sometimes speedo cables can "stick" in the sheath, so what happens is the cable "winds up" like a rubber band on one of those rubberband powered airplanes, then it will break loose, when it breaks loose it will often make a strange noise, and the speedometer needle will jump arround.
Try oiling the cable and see if that helps...
Old Aug 24, 2007 | 06:32 PM
ponyx2's Avatar
ponyx2
Needs a new cable
Old Aug 24, 2007 | 07:12 PM
Scott H.'s Avatar
Scott H.
Old Aug 24, 2007 | 08:05 PM
Norm Peterson's Avatar
Norm Peterson
Probably the cable is the root cause, and a binding cable will cause the driven gear at the end of the cable to shed teeth.
But before simply replacing only the inner cable, make sure the outer sheath isn't damaged.A sharp kink, crushed place, or torn spot (leak) will ruin the new cable pretty quicky too.
Norm
Old Aug 25, 2007 | 06:22 PM
Scott H.'s Avatar
Scott H.
