What wheel is this?
Old Aug 24, 2007 | 07:54 PM
baddog671's Avatar
baddog671
Default What wheel is this?
These wheels and tires came with my car and I plan on using them as my "junkies" until I get a set of Mag's. Anyone know what they are? They are atleast 7 years old and junk, tires are bald, but I just plan on using them to roll around the garage and to the shop.
I dont know if it is a Ford wheel. If you can see, the opening for the hub is much bigger than the diameter of the Granada hub. The lugs go on perfectly so its still 4 1/2.
And something unique, the washers that go behind the lugs are slotted.
Nic
Old Aug 24, 2007 | 08:11 PM
JamesW's Avatar
JamesW
Default RE: What wheel is this?
What you've got there is a typical set of Slot Style wheels..aka "Slots". They are also Unilug, in that you can change out that spacer to make it a different bolt pattern. These were very common in the mid 70s.
Here's some history.
http://www.kustomwheel.com/vintagema...=1181019316437
Old Aug 24, 2007 | 08:20 PM
baddog671's Avatar
baddog671
Cool, I was just curious. I kinda like them but they have that chaulky white buildup crap on them..
Old Aug 24, 2007 | 08:32 PM
JamesW's Avatar
JamesW
ORIGINAL: baddog671
Aluminum oxide. They can be polished back into shape...what a LOT of elbow grease*S*
Old Aug 24, 2007 | 08:37 PM
petec's Avatar
petec
Those aluminum slots bring back memories. I had a set on my 302 powered 85 Ranger. Are they 14" or 15"?
You can certainly polish them up with a buffing bonnet on a power drill and some rubbing and polishing compounds.
Old Aug 24, 2007 | 08:57 PM
htwheelz67's Avatar
htwheelz67
US mags..............they should come out with them in 17-18", they look great polished, everybody had them in the 70's
baddog671's Avatar
baddog671
They are 15, but I dont want to restore them. The outsides are only decently corroded but the insides are trashed from dirt, brake dust, etc etc...are they have kissed the curbs a few times it seems.
Old Aug 24, 2007 | 09:03 PM
doc540's Avatar
doc540
weren't those originally a po'boy's Hallibrands?
Old Aug 24, 2007 | 10:15 PM
JamesW's Avatar
JamesW
I always remember the ET slots. Geez..those were the days... jack'em up with air shocks and stick the tires out... rode like a tank
Old Aug 24, 2007 | 10:27 PM
LCC's Avatar
LCC
HAHAHAHA mine came with the same ones. I keep telling my friends they'll come back in style...[8D]
