HOW MUCH POWER
Old Aug 27, 2007 | 01:27 AM
ShAkE N BaKe!!'s Avatar
ShAkE N BaKe!!
Default HOW MUCH POWER
How much power can a stock 8" rear take?
and how much power can a C4 handle?
Old Aug 27, 2007 | 01:52 AM
67mustang302's Avatar
67mustang302
Default RE: HOW MUCH POWER
Dunno bout a C4, but I heard someone say an 8" will take 500rwhp. But I have no idea whether it's true or not. A lot of it will depend on how it's used. Launching on slicks with a transbrake or clutch dumps and it won't last as long as street tires with light launches. It'll also depend on the axles you use.
Old Aug 27, 2007 | 01:57 AM
Colorado_Mustang's Avatar
Colorado_Mustang
Depends on a few things. But, 400-450hp can flow through an 8" without too much trouble, as long as it's isn't beat on (hard shifts from drag racing, for example), or coming from a big-inch engine. The C4 would depend completely on the build. Stock isn't much more than 300hp, but they can be built to handle a lot more.
Old Aug 27, 2007 | 09:06 AM
highhilleer's Avatar
highhilleer
Something to think about. Ford used the 8" for up to 220 hp. Anything more than that (K-code {271hp}and big blocks) got the 9". Ford had to be more concerned about reliability than a single modifier person, but.... it's something to think about.
Old Aug 27, 2007 | 09:28 AM
urban_cowboy's Avatar
urban_cowboy
I know some drag racers prefer the c4 over the c6 because it has less power loss through the tranny due to being smaller and lighter. I can only assume they found a way to plant some pretty good power through them.
Old Aug 27, 2007 | 10:11 AM
Mustangdemon67's Avatar
Mustangdemon67
you can build the c4 to prlly handle about 4-500. rearend, i would go with a 9in anything over 300 just to be safe. and i assume its not your weekend cruiser if your building past 300hp
Old Aug 27, 2007 | 10:45 AM
SS4LUNCH's Avatar
SS4LUNCH
The C4 has been built up and can handle upwards of 900hp. It can be done. Look at Performance Automatic.
Old Aug 27, 2007 | 10:52 AM
RGH69's Avatar
RGH69
Here is one that will do up to 1000 HP.
http://www.dynamicracingtrans.com/fordtranny.htm
I have also seen DIY rebuild kits to 800 HP.
Old Aug 27, 2007 | 11:27 AM
my77stang's Avatar
my77stang
my 400-425 hp 302 chewed up and spit out my worn stock C4 (blew the planetaries out and the clutches were shot). but HD clutches/steels/bands, HD servo, and a good shift kit they will handle oodles of power. stepping into a better planetary and hardened input shaft ups the power handling even better
Old Aug 27, 2007 | 12:43 PM
RGH69's Avatar
RGH69
If you wanna rebuild it yourself, here is a good article.
http://www.mustangmonthly.com/projec...ssion_buildup/
And a video you can buy.
http://smartflix.com/store/video/373...ssion-64-to-69
