ENGINE IS IN THE SHOP!!!!!!!!!!!!!!!!!!!
Old Aug 28, 2007 | 07:34 PM
boogerschnot's Avatar
boogerschnot
Default ENGINE IS IN THE SHOP!!!!!!!!!!!!!!!!!!!
I need some help though,, I have a choice between these cams and need some opinions.. And I have a great story about the sale of my little Pontiac Sunfire to tell too, but that will wait until tomorrow..
Let me know which one sounds the best for my application.. A street driven, Daily driver 351w with get up and go that will go well at highway speeds, cause that is mostly all california driving is..
http://www.northernautoparts.com/Pro...tModelId=15044
http://www.northernautoparts.com/Pro...tModelId=11115
or
CS1084R
Small Block Ford w/o computer or emissions, Flat Hydraulic (62-87)
280 deg. / 290 deg.
.448" / .472
1500-4000
VS896R 1.70 or VS1555 1.82
VSR7017R
Old Aug 28, 2007 | 07:59 PM
my77stang's Avatar
my77stang
Default RE: ENGINE IS IN THE SHOP!!!!!!!!!!!!!!!!!!!
#2 or #3, #3 is pushing stock springs to the limits, but honestly i wouldnt recommend any of the above (is this what you are limited to?)
Old Aug 28, 2007 | 08:10 PM
petec's Avatar
petec
I wouldn't run any of the above. The advertised duration is really long given the specs @ .050 on the first two and you don't give that number for the third. Once that valve starts on it's way up you want it to get open as soon as it can and then close quickly. Long duration requires compression rato to be up as those long duration numbers mean the loss of cylinder pressure. Also, longer duration means higher RPM operating.
What compression ratio are you going to run?
Are you going to leve the stock springs in the heads?
What are your rear gears?
Old Aug 28, 2007 | 10:36 PM
JMD's Avatar
JMD
IDK, but I think I would want a cam that might get me to 5,500 at the top of the powerband....
4,000 rpm seems kinda low too me....
Old Aug 28, 2007 | 11:49 PM
boogerschnot
Thanks guys,, I dont know what to pick.. Im guessing that Im going to try and get ahold of one of the Performer cams anyway.. I have a couple of days before they start assembling the motor so, I will try to find one around here.. That or go over to crane or comp.. Thanks for the info..
Old Aug 29, 2007 | 01:38 AM
blueovalboy7's Avatar
blueovalboy7
Sorry I'm no help, but glad to hear you got the motor to the shop.
Old Aug 29, 2007 | 12:46 PM
boogerschnot
So, I am ordering the Performer (as I had planned before) and just having it 2 day shipped to the shop,, so no worries about that..
Old Aug 29, 2007 | 01:31 PM
eescapethefate's Avatar
eescapethefate
which one did u get
Old Aug 29, 2007 | 01:35 PM
takeoutexodus's Avatar
takeoutexodus
since then engine is in the shop , might as well get a full rebuild done
hahhah jk
Well what else are you doing to the engine ?
Old Aug 29, 2007 | 01:42 PM
boogerschnot
I got the edlebrock 2182 from Jegs http://www.jegs.com/webapp/wcs/store...10002_34762_-1
total was $157.98 with two day shipping straight to my machine shop.. They are going to bore the motor 030 over, and do a long block build. I was going to have the heads ported but decided against (mostly because of cost, and they dont do it there) Then they will deliver it to me after its all done!!! Probably next tuesday, due to the long weekend..
