GT40-P Headers on a classic???
Old Feb 8, 2005 | 03:55 PM
Wessy's Avatar
Wessy
Default GT40-P Headers on a classic???
I was wondering if anyone here might know where I could find a set of GT40-P headers that fit the early models? I have tried numerious vendors and all say the same thing. "We used to have those" or "You have to get them custom made." Somehow I know there is a company out there that makes these headers. I have a 68 coupe that I am restoring and this is the only part that keeps me from firing up the engine. Thanks!!!
Wes
Old Feb 8, 2005 | 04:03 PM
69mach1377's Avatar
69mach1377
Default RE: GT40-P Headers on a classic???
Are GT40-P heads much different than other small block heads, bolt pattern etc?
Old Feb 9, 2005 | 10:59 PM
Wessy's Avatar
Wessy
This is really the best site for info on the GT40-P heads. Loads of info about them. Only problem is they don't really talk about these heads in the early model stangs. It seems only a select few use the heads for this application.
Old Feb 11, 2005 | 12:52 AM
69mach1377's Avatar
69mach1377
By the time you get an exhaust system to work...you could buy some good old standard aluminum heads with known header fitments....
Old Feb 11, 2005 | 08:37 AM
Soaring's Avatar
Soaring
I ♥ Acer
If you could get a 5.0 head to fit your engine, then there are all kinds of GT40-P headers for the 79's and up. Personally, I use JBL Shorty ceramic coated headers, and was quite pleased how they increased the HP on my 289.
Old Feb 13, 2005 | 02:40 PM
Wessy's Avatar
Wessy
Well having a 68 the 79 and up headers don't really work for me. I already bought a set of Mac Shorties for 79-92 and didn't have any luck. So after about 3 days of searching I ran across centralcoastmustang.net who just so happens to sell a set of
long tube headers for the GT40-P heads for years 65-70
. I have ordered a set and should have them by fri this week. I hope they fit. If they don't fit anyone want a set of New GT40-P heads in exchange for something equivalent?
Old Feb 13, 2005 | 05:09 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: Wessy
Let us know how it turns out Wes.
Old Feb 23, 2005 | 09:12 PM
Wessy's Avatar
Wessy
Well you wanted to know how it went so here it is....
I got the new headers in on monday and I couldn't be happier with them, ok well I guess I could be a lilttle bit happier. The headers fit almost perfect only problem is that where the 2 y's meet they touch the trans bellhousing. I don't really see this as a problem since the engine, trans and headers all move as one unit. What concerns me it the vibrations causing the bellhousing to rub a hole in them. I have no clue as to how to fix this issue nor do I know if I should even be worried about it. The only other complaint I have is the 3rd primary on the driver side makes it a lil hard to get the spark plug in. Well here a some pics to look at:
BTW these are made by centralcoastmustang.com Part #CCM-6570
Old Feb 24, 2005 | 12:43 AM
69mach1377's Avatar
69mach1377
Rubbing solution = grinder
Remove some material, but not too much. 1/8" clearance should be fine...
Old Feb 24, 2005 | 01:19 AM
Wessy's Avatar
Wessy
Yeah that's what I was thinking only thing is that means I have to spend another hour taking the bolts off the headers so that get clearance for a grinder
GimpyHSHS
19
Dec 19, 2023 01:12 PM
fastbackford351
Oct 1, 2015 12:24 PM
guitarman376
Sep 30, 2015 05:54 PM
junior04
Sep 28, 2015 10:53 AM
BrantleyS550
Sep 14, 2015 04:18 PM
