rear end help
Old Sep 1, 2007 | 01:35 AM
390bigblock's Avatar
390bigblock
Default rear end help
i have a 9inch rear end right now i dont know what the gears are right now but i saw this on craigslist http://sacramento.craigslist.org/pts/411133852.html would this be much of a downgrade? i really want to get it cause it comes with the disk brake setup is it a good deal if the gears in it are good?
Old Sep 1, 2007 | 09:56 AM
Starfury's Avatar
Starfury
Default RE: rear end help
I can't tell what it's sitting under, but if it's not a fox, it won't fit under your car,and even if it is, you're going tohave to weld new perches onto it. Plus, you've already got a 9", there's no reason to downgrade. Worry about gears, not adding rear discs. You can do that later if you really want to, but it's not really necessary unless you're taking it to the track often.
Old Sep 1, 2007 | 10:47 AM
baddog671's Avatar
baddog671
Not too bad a price on that. It's alittle too wide for your application I believe, but wouldnt be much of a problem. You would also need to move the perches, like said above. Just because you have a 9" doesnt necessarily mean a 3.08 gearing would be a downgrade. I have 2.73 on mine...
If you have the buck tag on it still, it says..
Old Sep 1, 2007 | 11:21 AM
Starfury's Avatar
Starfury
I meant downgrade from a 9" to an 8.8. Sure, the 8.8 is lighter, and a great upgrade from an 8" if used behind a small block (I've got one at a friend's ready for me to build for my 67)...but keep the 9" behind your big block. You might appreciate it down the road
Old Sep 1, 2007 | 11:28 AM
baddog671's Avatar
baddog671
Haha, I thought you were meaning downgrade in gearing. Yes, especially with a 390 I would stay with a 9", I didnt realize what engine he had.
Old Sep 1, 2007 | 01:13 PM
390bigblock
ya thanks sounds like a no go on that rear end ill just use that money to fix the tranny leak thanks for your help
mtgldr
Feb 3, 2024 09:00 PM
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
fastbackford351
Sep 12, 2015 09:42 AM
Dragonus18
Sep 9, 2015 01:21 AM
