Spindles
Old Sep 1, 2007 | 10:28 AM
StangDB's Avatar
StangDB
Default Spindles
Are 67 6Cyl spindals the same as V8? Probably not right?
Old Sep 1, 2007 | 10:43 AM
baddog671's Avatar
baddog671
Default RE: Spindles
They are different
Old Sep 1, 2007 | 09:40 PM
restomod@16's Avatar
restomod@16
the only difference is strength
Old Sep 2, 2007 | 01:51 AM
degins's Avatar
degins
Third answer is the charmer. They are identical. 65-66 6 cylinder type are different than the 8 cylinder.
Old Sep 2, 2007 | 01:59 AM
restomod@16
i always thought that the v8 spindles were made from a stronger steel in order to handle the higher block weight? i may be wrong... but i do know for a fact that they are identical in shape and the taper is the same too. I did a disc brake swap and i had ordered my kit for a 67 v8 when i really have a I6 but there is no fitment difference (at least not any noticable ones [8D]) ... they fit perfectly and work awesome too!
Old Sep 2, 2007 | 07:58 AM
andrewmp6's Avatar
andrewmp6
why do you ask are you wanting disc brakes or another reason
Old Sep 3, 2007 | 08:07 PM
StangDB's Avatar
StangDB
Yes, well that and power rack and pinion. i am going with a 302 bored out 60 over. and i got all new parts for it. eddlebrock 2x4 intake. Is ther any place to buy new V8 spindals for a 67?
Old Sep 4, 2007 | 12:27 AM
JMD's Avatar
JMD
As Degins says,,,All spindlesare the same on a 67.... you do not need new spindles..... Save your cash!!!
As far as I know, no one reproduces early Mustang spindles, if you were to need them (you don't) you would have to get them used. We got our spindles for the 66 from ebay, $200.00 a pair...
Old Sep 4, 2007 | 01:08 AM
Shrinkdude's Avatar
Shrinkdude
ORIGINAL: JMD
http://www.discbrakeswap.com/
He reproduces them with the Granada brakes but with a fixed geometry for the early cars.
Not bad price for brand new spindles.
If the spindles are the same you should be able to buy the bracket to attach the calipers to the spindles from NPD or another Mustang parts place.
Old Sep 4, 2007 | 01:11 AM
andrewmp6's Avatar
andrewmp6
id go the granada swap kit or the 71-73 spindles they are the thickest ones used on a early mustang and you can get almost any big brake set up out here.if you want baer brakes cheap http://www.mustangsteve.com/cobrabrakes.html the cobra brakes are pbr samething baer brakes really are just restamped.
