best bang for your buck ?
Old Sep 3, 2007 | 07:54 PM
takeoutexodus's Avatar
takeoutexodus
Default best bang for your buck ?
So what heads do you think give you the best bang for your buck .
Combos for internals and engine and all of that sort , But i heard parting it out to only what you want is the best way to do it .
I remember reading on MF that Patriot heads are new and very good .
But i dont know what to look for .
later 302 block is what its going into.
Old Sep 3, 2007 | 07:58 PM
cmc30250's Avatar
cmc30250
Default RE: best bang for your buck ?
i've heard really good things about Trick Flow heads, check them out
Old Sep 3, 2007 | 08:08 PM
67mustang302's Avatar
67mustang302
AfR 165's, Eddy Performers or Perf RPM's. Good bang for the buck is GT40's, won't make the same power as the aluminum ones, but don't spend as much money, either
Old Sep 3, 2007 | 10:28 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
the biggest bang for your dollar would be to get gears and make sure the car hooks up nice
Old Sep 3, 2007 | 10:37 PM
takeoutexodus
yeah its all a big plan to have an entire restomod ..
what percentage do you think the gearing and Tranny make in a cars overall RWP?
Old Sep 3, 2007 | 10:56 PM
middiepride's Avatar
middiepride
ORIGINAL: takeoutexodus
its not so much an increase in hp because you will still have driveline losses reagardless. but the car will plant the *** and take off like a shot, not up in smoke and that makes it faster, obviously
the suspension is key in many ways, its useless to have 600 hp and this and that if you've got tires that dont hook and just spin
Old Sep 3, 2007 | 11:30 PM
takeoutexodus
haha yeah , that was the initial plan to keep them down
though i havent looked much into the suspension aspect of this project yet.
any suggestions?
budget project too ...so lets keep this reasonable.
Old Sep 4, 2007 | 01:16 AM
andrewmp6's Avatar
andrewmp6
what about the gt40p heads
Old Sep 4, 2007 | 09:19 AM
fastbackford351's Avatar
fastbackford351
Foghorn Leghorn
You can get a nice set of FoMoCo SVO heads for decent money. Good streetable power and that oh so important factory Ford engineering.
You can get the aluminum versions of the GT40 head or lose your mind and get those X303 heads, ( I think that is what they are called). In any event, all of the Ford heads are comparable in price to their aftermarket counterparts.
Old Sep 4, 2007 | 11:05 AM
67mustang302
But that aftermarket heads make more power
And gearing makes a HUGE difference in power at the wheels. It's gear multiplication. A 4.00 gear will make 33% more power at the wheels than a 3.00 gear. Dynos don't measure actual torque at the wheels, but through a series of calculations determine the "power at the wheels" after drivetrain loss as it relates to engine power. In reality you're making several thousand ft-lbs at the wheels in 1st gear, less in 2nd, less in 3rd etc. Gearing will bump that power up with lower gears, but you need the rpm range in the engine to match it and have the right power/speed in gear
