71-73 Seat Frames
Old Sep 9, 2007 | 09:23 PM
Fordication's Avatar
Fordication
Default 71-73 Seat Frames
Anyone have an idea where you can get seat frame replacements or some kind of bolstering for the stock seat bottoms. My legs keep falling asleep because my *** sinks so low in the seat that my legs are over metal bars. BTW I am 5'10 and 190 so no fat **** jokes.
Old Sep 9, 2007 | 09:58 PM
RSRXION's Avatar
RSRXION
Default RE: 71-73 Seat Frames
I'm 6'3" and 250 and I have the opposite problem after the restoration. The original seat foams in my car were not near as thick as the reproduction replacement pads. The end result was that I now sit3 inches higher and 2 inches forward. I wound up putting tilt column in the car to make entry and exit easier.
With this in mind , you might consider replacing the foams and the upholstery. Kind of an expensive proposition but ...
Good luck, Dean
Old Sep 9, 2007 | 11:35 PM
Fordication
You think the foam could do the trick? I mean when I sit down the seat bottom springs go down a bit. Below the frame as I said. No the upholstery looks like new. If anything I would add the foam but I am afraid all it will do is lift me higher but still cut the circulation off to my legs. We will see. My car came with tilt. That is a cool feature.
Old Sep 10, 2007 | 02:09 AM
andrewmp6's Avatar
andrewmp6
have a good upholstery shop add a little foam to them are the same thickness just a little harder foam.dont feel bad my 68 still has the factory foam in the seats and i sink im them.im 6'2 250lbs i need to buy better buckets just aint got around to it.
b8checker
Oct 8, 2015 12:55 PM
jrrhd73must
Oct 2, 2015 09:17 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
GT350 S550 Tech
Sep 29, 2015 03:29 PM
mrappe
Sep 26, 2015 10:16 AM
