Anyone with a 67
Old Sep 17, 2007 | 11:11 AM
zmetalmilitia's Avatar
zmetalmilitia
Default Anyone with a 67
I am in need of measurements to weld on the two parking brake brackets to the floor pans under the car. Can anyone with a 67 help me out? I want to get that under part painted before the cold weather sets in. Just some reference measurements would be great, like off the floor supports or rockers. Anything would be great!!
Old Sep 17, 2007 | 02:11 PM
dozierstang's Avatar
dozierstang
Default RE: Anyone with a 67
The parking brake brackets do not weld on to my 67. The brackets have a hole that slides over a stud and are held on with cotter pins. Is it the stud that you want to weld on?
Old Sep 17, 2007 | 04:51 PM
zmetalmilitia
Yes I guess that is what I want. I thought they welded on there. My floor pans were toast and needed replacing. I replaced them but had no reference for the brackets. So there is a stud that welds to the floor pans on each side then the brackets are held on there with cotter pins? Does anyone have any pics? Thanks for any help!
Old Sep 17, 2007 | 05:03 PM
Stevetra's Avatar
Stevetra
I have 1 welded bracket on my parking brake cable...Is this what you need?
Here are some pictures...not very good, but the best I could do on the ground.
I measured using the frame extensions as a refrence:
http://i177.photobucket.com/albums/w...a/P1040047.jpg
http://i177.photobucket.com/albums/w...a/P1040044.jpg
http://i177.photobucket.com/albums/w...a/P1040045.jpg
Hope this helps.
Old Sep 17, 2007 | 06:35 PM
zmetalmilitia
Those pics are great. They will really help. Are those pics of just one of the brackets? Which side? I am in need of attaching both brackets, I believe there are two, one on each side of the transmission tunnel, under the front seats. If there are two, I should be able to weld them on yes?
Old Sep 17, 2007 | 07:53 PM
Stevetra's Avatar
Stevetra
This bracket is on the drivers side....umm...my car only has one, on the drivers side.
Old Sep 17, 2007 | 08:16 PM
Stevetra's Avatar
Stevetra
here is another pic, I found on the web.
http://www.modifiedmustang.com/Images/mcl137.jpg
This shows the whole assembly.
I got this pic from this site: http://www.modifiedmustang.com/mymustang_restored.htm
There is alot of pictoral into here
Old Sep 18, 2007 | 12:17 PM
zmetalmilitia
Those pics are great. Thanks for the hook up! I will be able to finally finish the undercarriage. At least I think.
