Torque settings?
Old Sep 21, 2007 | 05:35 PM
baddog671's Avatar
baddog671
Default Torque settings?
Is there a specific torque setting for the front leaf spring bolts and the little ones on the shackles? Obviously I dont want them too loose but I dont want to tighten too much and squish the bushing. Midolyn if it matters.
Also, my original bushingswere a pain in the butt to remove. They were very snug in the hole. The replacements aren't the same. They are loose enough I can move the leaf slightly laterally. Is this normal?
Old Sep 21, 2007 | 05:39 PM
67mustang302's Avatar
67mustang302
Default RE: Torque settings?
I'm sure there's a torque setting, I just make them tight, but without smushing stuff. And the new bushings should fit snugly, my poly shackle bushings did NOT go in easily, but that may just be poly
Old Sep 21, 2007 | 05:44 PM
xswoopr's Avatar
xswoopr
spring shackle bars to body and spring - 15 to 22 ft/ lbs
spring to spring front hanger nut - 30 to 50 ft/lbs
spring to axle u-bolt nut - 30 to 45 ft/lbs
Old Sep 21, 2007 | 05:49 PM
baddog671's Avatar
baddog671
I mean, it isnt LOOSE, but it sure isnt as snug as the originals. I can only get about a cm of lateral movement, less on the passenger's side. I just figured there would be no play in it whatsoever. Ill have a stabilizer bar in there too, so it shouldnt be a problem, right?
Old Sep 21, 2007 | 05:52 PM
baddog671's Avatar
baddog671
ORIGINAL: xswoopr
Thanks Bud!
Old Sep 21, 2007 | 06:08 PM
baddog671's Avatar
baddog671
Oh, and btw, should everything be snugged up after its on the ground? Like the same for the front to prevent resistive pressure...
Old Sep 21, 2007 | 06:19 PM
bluovalguy's Avatar
bluovalguy
Yeah, wait till it is on the ground to tighten them, or it will squeak.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
TCStangerv6
Oct 11, 2015 05:57 PM
mustangheaven
Oct 7, 2015 10:23 AM
guitarman376
Sep 30, 2015 05:54 PM
wraith777
Sep 28, 2015 10:49 AM
