stupid question number one...
Old Sep 30, 2007 | 03:24 PM
jozieeeeee's Avatar
jozieeeeee
Default stupid question number one...
out of a lot that you can be sure will be coming.
anyway! My mom put too much oil in my car, really, I'm not just saying it was her to save my ***, it was. I looked it up and read that too much oil can wreak havoc on your engine.. and I also read that you should use a turkey baster & some thin tubing, put it in the hole for the dipstick, and pull some oil out. I trust the people in this forum a whole lot more then others, so is doing that okay?
Old Sep 30, 2007 | 03:31 PM
jeffro22's Avatar
jeffro22
Default RE: stupid question number one...
you could do it that way or take the drainplug out and use your thumb to let oil out. A little messier that way. how much oil do you have in the motor.
Old Sep 30, 2007 | 04:19 PM
Tony R's Avatar
Tony R
I agree on pulling the plug to remove some oil. Get ready to get oily. Have rags handy.
Old Sep 30, 2007 | 04:24 PM
JamesW's Avatar
JamesW
how much over did she put in there?
Old Sep 30, 2007 | 04:46 PM
jozieeeeee's Avatar
jozieeeeee
it's past the "maximum" mark
Old Sep 30, 2007 | 04:50 PM
baddog671's Avatar
baddog671
Get 2 milk jugs and a funnel and drain it out into the jugs. Then measure it and pour it back in. Would be alot easier than sucking it out the dipstick tube.
The 289's and 302's take 5 quarts I believe. If you have an i6, not sure for those.
Old Sep 30, 2007 | 06:17 PM
JamesW's Avatar
JamesW
ORIGINAL: baddog671
Yeah... and go buy some of those cheap disposiblelatex painter's gloves so you don't get oil all over your hands.
Old Sep 30, 2007 | 06:27 PM
knuckless's Avatar
knuckless
or you could just change the oil and drain the whole thing, saves a mess and its something that needs to be done every few thousand miles
Old Sep 30, 2007 | 06:57 PM
bluovalguy's Avatar
bluovalguy
ORIGINAL: JamesW
ORIGINAL: baddog671
Since we had the baby, I do almost everything in the gloves. Makes it so much easier to clean up.
Old Sep 30, 2007 | 08:44 PM
Bulldog66's Avatar
Bulldog66
Just get a drain pan and let out what you think it's over and re-check it. It's nothing to get stressed about.
If you're just wanting to start from scratch, clean the drain pan and drain it all. Even if you're out 5 quarts of oil, you're just out 10 bucks at best. (unless you're using synthetic, then I suggest just draining what it's over.)
Cheers.
