cc4 to aod conversion
Old Sep 30, 2007 | 07:55 PM
arkight's Avatar
arkight
Default cc4 to aod conversion
Ifound a aod out of a 88 or 89 5.0 i cant remember the year itwas one of those. Is this the one that dosent have a computer? Basically will it work.
Old Sep 30, 2007 | 08:52 PM
deadcarnahans's Avatar
deadcarnahans
Default RE: cc4 to aod conversion
88 and up AODs were better than 87 and earlier.
Mustangs were computer controlled starting in 94.
It will bolt in and work if you know how to hook up the linkages correctly.
You'll have to fabricate a crossmember or buy one. The speedo cable will be too short. Long tube headers won't fit unless modified. ( I used shorties last time I did this swap.)
Use the slip yoke that came with the AOD and check driveshaft length
Old Sep 30, 2007 | 09:48 PM
Mr. Classic EFI's Avatar
Mr. Classic EFI
Dont forget the TV cable!! Hedings 2& 3
http://www.becontrols.com/tech/tech.htm#topten_q2
Old Sep 30, 2007 | 09:59 PM
andrewmp6's Avatar
andrewmp6
you might want to build it up a little i have exploded a few aods in stock fox bodys before but i got a lead foot.later on you might want to regear your rear end to a 3.55 or 3.73
HRnB
GT350 S550 Tech
Dec 18, 2015 09:35 AM
Nov 10, 2015 11:39 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
CarrieS
Sep 1, 2015 01:00 PM
