Rear sway bars?
Old Oct 1, 2007 | 01:06 PM
baddog671's Avatar
baddog671
Default Rear sway bars?
If anyone has pictures of their rear sway bars, especially how it mounts, could you post them so I can compare? Thanks
Old Oct 1, 2007 | 01:17 PM
67mustang302's Avatar
67mustang302
Default RE: Rear sway bars?
Just put the leaf spring clamps on loosely with the Sway bar bolted to them loosely and kinda move it around till you find the best place to mount the subframe brackets, then mark them and drill. It's gonna vary from car to car when you consider exhaust pipe placement, the springs they're using etc. Just make sure that there's no interferance with parts(ie the sway bar mashing the exhaust pipe etc)
Old Oct 1, 2007 | 01:22 PM
blue66mustang's Avatar
blue66mustang
Here is an ADCO 1" mounted on the rear of my 1966. YMMV.
http://i40.photobucket.com/albums/e2...G/IMG_1844.jpg
http://i40.photobucket.com/albums/e2...G/IMG_1839.jpg
http://i40.photobucket.com/albums/e2...G/IMG_1836.jpg
Also remember that you need ALL of the normalweight of the car on the rear suspension when buttoning things up. I had to move the jacking point durring my install to in front of the lower controll armbecause the engine was holding the rear up to far.
Old Oct 1, 2007 | 04:17 PM
baddog671's Avatar
baddog671
Thanks for the pics Blue. Mine is alittle different..the endlinks are on the leaf springs and the straight brackets are on the railing. It looks like its gonna be a sharp angle (bar at a 45* up to frame)and I just wanted to be sure.
Old Oct 1, 2007 | 04:24 PM
blue66mustang
I believe that is the factory setup. The leafspring plates on the OEM partshave the end link hole on them. Like Isaid when I installed mine I swore the were wronguntill I properly loaded the rear suspension.
Good luck.
Old Oct 1, 2007 | 04:41 PM
baddog671's Avatar
baddog671
Cool, thanks.
I got another question, Ill post it in here so I dont have to open another thread. Should I make sure my back tires are tracking straight or is it a moot point? How would u go about measuring that? I figured those little pegs on the springs would only need to be 1/4" off to screw it all up..
Nic
Old Oct 1, 2007 | 07:03 PM
67mustang302
The axle housing has bolts that go through the leaf spring, the only way to really check rear tracking is to take it to an alignment shop and have them check and realign if necessary
Old Oct 1, 2007 | 07:23 PM
blue66mustang
+1 on that too. They should be able to throw the alignment heads on all 4 wheels. That should let you know right away.
BTW I thought you had a FORD ? Isn't dogtracking a GM problem...
Old Oct 1, 2007 | 09:13 PM
baddog671's Avatar
baddog671
ORIGINAL: blue66mustang
Lol, you never know, its 40+ years old...
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
Gene K
Oct 21, 2015 11:37 PM
Sep 16, 2015 07:53 PM
fastbackford351
Sep 12, 2015 09:42 AM
robjh22
Suspension
Sep 8, 2015 12:47 PM
