rear disk brake swap????
Old Oct 2, 2007 | 01:18 AM
erikfall's Avatar
erikfall
Default rear disk brake swap????
i have a 65 stang i6 i currently have manual front and rear drum brakes....i plan on swaping my front drum to a 5 lug manual disk brake system sumtime this week & and it only makes sense to also do a 5 lug disk brake conversion to the back....is there a drum to disk brake conversion thats fairly easy to install....im a newb so explain in detail in words i can under stand please
Thanks
Old Oct 2, 2007 | 06:12 AM
JamesW's Avatar
JamesW
Default RE: rear disk brake swap????
There are a dozen or so different options...from new aftermarket kits from people like SSBC and Baer, all the way down to pulling junkyard units off compatible Fords and transplanting.
Here's one option...
http://www.midnightdsigns.com/Mustang/Rear_Brakes.htm
Old Oct 2, 2007 | 06:45 AM
andrewmp6's Avatar
andrewmp6
to do what you want you need new spindles hubs brakes springs and shocks front and back a new rear end 8 inch atleast. get your rear end from http://www.perogie.com/Rears.htm on brakes if get http://www.mustangsteve.com/cobrabrakes.html the cobra brakes are pbr same thing baer really is.since your replacing the spindles the 71-73 mustang ones are thicker stronger and fit fine.
Old Oct 2, 2007 | 01:52 PM
cordoba@California's Avatar
cordoba@California
Maybe this Will help comes with everything!
http://store.summitracing.com/partde...p;autoview=sku
spectreman
Mar 31, 2016 09:26 PM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
DCole24
Sep 11, 2015 10:50 AM
CarrieS
Sep 1, 2015 01:00 PM
Fast-Hands
Aug 19, 2015 06:54 AM
