Found a $75 4bbl carb
Old Oct 2, 2007 | 12:23 PM
boogerschnot's Avatar
boogerschnot
Default Found a $75 4bbl carb
http://sandiego.craigslist.org/pts/437679431.html
Good Buy? I will need a good 4bbl sometime..
Old Oct 2, 2007 | 12:29 PM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
Default RE: Found a $75 4bbl carb
i would say go for it, how often are you gonna find a 4bbl for $75, i dont know much about rebiulds, but they dont seem to be too expensive.
Old Oct 2, 2007 | 12:32 PM
Jaded's Avatar
Jaded
Check to see if the lower butterfly shaft is wobbled out. They have a tendency to leak there.
Old Oct 2, 2007 | 12:37 PM
USMCrebel's Avatar
USMCrebel
if its wobbled out what does that mean as far as the integrity of the carb goes?
Old Oct 2, 2007 | 12:42 PM
Jaded's Avatar
Jaded
They leak like a sieve, right onto the intake and of course jack up vacuum. Supposedly there was a kit to fix the problem, but it wasn't all that great.
I have one just like it.
Old Oct 2, 2007 | 12:47 PM
USMCrebel's Avatar
USMCrebel
if you rebuilt the entire carb would it matter?
Old Oct 2, 2007 | 12:48 PM
Jaded's Avatar
Jaded
Not really. The problem isn't the shaft itself, it's the hole through the carb body.
Old Oct 2, 2007 | 01:09 PM
nealro's Avatar
nealro
even if it's junk, for $75 it's worth picking up just for the spare parts.
Old Oct 2, 2007 | 01:10 PM
my77stang's Avatar
my77stang
arent there teflon bushings on the shaft that can be replaced?
Old Oct 2, 2007 | 01:36 PM
Jaded's Avatar
Jaded
There are teflon or phenolicbushings there, and if I recall right, that was how they fixed the problem. When mine started, I was at a car club meeting where we discussed this. I would add, that these guys drag race their cars, and are in their late 60's, so they aren't novices.
If I was going to buy a carb, mind you, 75 is worth the parts, IF you have that carb, I would check the shafts, see if all the fuel bowl screws are proper, and make sure that they are still holding thread. It would get a complete rebuild before going on my engine.
