Front Frame Rail Woes
Old Oct 2, 2007 | 04:53 PM
Curse The Sky's Avatar
Curse The Sky
Default Front Frame Rail Woes
I knew my car had problems, but MOST of the stuff underneath seemed solid (with the exception of the floorpans, and thus the cowls). Unfortunately, I started prodding around, and found that the front frame rails are rotting away. They're still solid, but they won't be if I don't do something about them soon enough.
What do you usually do, just weld patches into them? Am I risking completely destroying the alignment if it isn't perfect? Are there any other options, other than finding a new car?
Thanks.
Old Oct 2, 2007 | 05:09 PM
jlg2002's Avatar
jlg2002
Default RE: Front Frame Rail Woes
you can buy all of the sheet metal you could ever want from several sources. (NPD is a good choice) Mustang monthly has technical articles on how to do most of these exchanges. I'm not going to fool you into thinking it's a piece of cake cause it is some work and you need some decent mechanical skills to do it.
Old Oct 2, 2007 | 05:30 PM
Curse The Sky
I wasn't too concerned about the work or the materials, but more with how "gone" the car is when the front frame rails are rotting. I guess it's not all that uncommon of a repair after all, which makes me feel a lot better.
Thanks.
Old Oct 2, 2007 | 07:36 PM
plainsman1876's Avatar
plainsman1876
All you have to do is replace the frame rails , If I were doing it I would replace all the frame rails and then add sub frame connectors
Old Oct 2, 2007 | 08:27 PM
zmetalmilitia's Avatar
zmetalmilitia
I replaced both front frame rails on mine and it is some work. I built a jig that the car sat on to line everything up before i started cutting. As long as you don't move anything, the new frame rails should line right up and weld them in.
Old Oct 2, 2007 | 08:44 PM
tarafied1's Avatar
tarafied1
ORIGINAL: zmetalmilitia
I also replaced everything in front of the firewall. I put the car on a rack, welded up some jigs to line all the bolt hole to and did one side at a time. It is a lot of work but much better than patching the car up. I also added torque boxes to both sides and subframe connectors.
[IMG]local://upfiles/56180/947DE4D563554C1C9C1787812BDCFF67.jpg[/IMG]
[IMG]local://upfiles/56180/9CA1A6047AF1447FB9744E6598A45A17.jpg[/IMG]
[IMG]local://upfiles/56180/BC7141F5E4E34933B21FE2B9A8A878E0.jpg[/IMG]
winner99
Oct 1, 2015 01:06 PM
winner99
Oct 1, 2015 10:52 AM
mdg
Oct 1, 2015 07:04 AM
UrS4
Sep 30, 2015 10:13 AM
mrappe
Sep 26, 2015 10:16 AM
