t5 or 4 speed
Old Oct 2, 2007 | 04:54 PM
miggy68stang's Avatar
miggy68stang
Default t5 or 4 speed
i bought this engine/tranny off of ebay and it was advertised as a 85 mustang302 with borg warner four speed. there is no id tag but here are the numbers i found on the sides of the tranny. 13-52-065-908, 13-52-066-919, kf287158. i already searched those numbers on google and one site said it was a t5 but i wanted more proof before i went and bought a shifter, and t5 install kit. thanks for any help!!
mig
Old Oct 2, 2007 | 04:57 PM
fast65's Avatar
fast65
Default RE: t5 or 4 speed
Just wait to get the tranny and if it has 5 speeds then....boom there's your answer.
Old Oct 2, 2007 | 05:00 PM
miggy68stang
i have the tranny and it doesn't have a shifter. how else can i check?
Old Oct 2, 2007 | 05:23 PM
Rorin67's Avatar
Rorin67
Did 85 Mustangs even come with 4-speeds? Post a pic of it and we can tell in one second.
Old Oct 2, 2007 | 06:04 PM
miggy68stang
Here's the links to see the pics
http://i215.photobucket.com/albums/c...Picture048.jpg
http://i215.photobucket.com/albums/c...Picture047.jpg
http://i215.photobucket.com/albums/c...Picture049.jpg
http://i215.photobucket.com/albums/c...Picture050.jpg
Old Oct 2, 2007 | 06:06 PM
67mustang302's Avatar
67mustang302
Post a picture, a T5 and a 4spd look quite different
Old Oct 2, 2007 | 06:12 PM
miggy68stang
Old Oct 2, 2007 | 06:15 PM
67mustang302
Looks like a T5
Old Oct 2, 2007 | 07:06 PM
Daze's Avatar
Daze
That is definitely a T5 however if it is from an 85 than it is NOT world class unless it was changed out and a non WC T5 is not very strong. If it is not WC than it will use gear oil if it is WC than it needs to have ATF fluid in it. The numbers on the side of the tranny won't actually tell you anything because those are casting numbers for the case and even though similar to tag numbers not the same. The numbers you need should be on a tag, if the tag is gone contact Glen of http://www.rosehillperformanceparts.com/ He will be able to tell you how to tell the difference between a WC and non WC T5 with out the tag. Tell him Day sent you and he will take good care of you.
Old Oct 2, 2007 | 07:23 PM
67mustang302
http://www.gforcetransmissions.com/ Use one of their T5 upgrade kits and it'll turn that tranny, even if it's a non WC, into a total beast
