t5 or 3550
Old Oct 6, 2007 | 10:17 PM
dcohen's Avatar
dcohen
Default RE: t5 or 3550
where can i buy the g-force kit? bout how much does it cost?
Old Oct 7, 2007 | 12:25 AM
67mustang302's Avatar
67mustang302
http://www.gforcetransmissions.com/
Old Oct 8, 2007 | 11:44 AM
67Stang68's Avatar
67Stang68
Torque is what Im worried about with my T-5. It will be behind a 347 with a Z303 cam and AFR185 heads. The T5 I have is out of a 91 GT. Here is a quoteabout those trannies, note the 300 ft lb torque rating. Im hoping to be a little over that. My friends arewagering bets as to how long it will last.Most say 2 months. The first month I will baby it and the second month I wont be able to resist not babying it.
"1990 to 1993 the stock Ford production V-8 WC T-5 was upgraded with stronger 3.35 gear set by increasing the nickel content to produce a harder, stronger gear. 2nd and 3rd gear ratios were decreased slightly tp provide more torque to the rear wheels. Synchro linings on 3rd, 4th were improved by changing from fiber linings to carbon fiber to further improve the friction surface resulting in better high rpm shifts. A longer throw shifter was installed to "make shifting easier". The speedo drive gear was changed from 7 tooth to 8 tooth. The 8 tooth was a step backwards when installing lower rear axle ratio greater than 3.55 as the driven gear is limited to 21tooth count. Yes, 23 tooth gears are available but do not last long as the teeth are thin and do not mesh correctly. Torque rating jumped to 300ft/lbs."
As for anyone who wants to purchase the tremec 3650that I cant use, Note it cant be used in a non modular motor. If your running a 4.6 great, you can use it.
Old Oct 8, 2007 | 01:44 PM
dcohen's Avatar
dcohen
that g-force kit looks like the way to go, anybody had any experience with it?
Old Oct 8, 2007 | 01:48 PM
67mustang302
There are guys running street cars into the12's on stock T5's, it takes more than 300ft-lbs to do that. If you drive well and shift properly(ie, no power shifting, clutch dumping etc) it should last for quite a while, and for about $1,100 that GForce kit will basically double the power capacity for the T5
Old Oct 8, 2007 | 01:53 PM
dcohen's Avatar
dcohen
ill probably find a stock t-5 and have it rebuilt and use it till it breaks, then upgrade to the g-force kit
hopefully the stock t-5 will last a while, if i drive with some care
thesource
Jan 11, 2007 06:32 PM
jacrowder
Dec 17, 2006 05:24 PM
brywatz
Nov 1, 2006 11:51 PM
shaners90lxhatch
Sep 10, 2006 05:17 PM
tbirdmatt66
Jul 8, 2006 12:57 AM
