stroked 351w or 460?
Old Oct 6, 2007 | 08:11 PM
Mustang.'s Avatar
Mustang.
Default stroked 351w or 460?
i was wondering if what i should go with, a stroked 351w (393, 408, 420?), or a big block 460, for my 68 coupe?
Old Oct 6, 2007 | 08:53 PM
easttennmotors's Avatar
easttennmotors
Default RE: stroked 351w or 460?
you havent specified what your looking for at all as far as usage and performance and drivability
Old Oct 6, 2007 | 09:16 PM
fastbackford351's Avatar
fastbackford351
Foghorn Leghorn
Neither one is original to the car so just shooting from the hip I'd saygo big. I often wishthat Iwould have done the FE rebuild and swap on my 67. I have a perfectly good 390 sitting on the floor.[&o]. So if you have access to a nice big block, given it to do over again, I'd probably say "What the hell?!" and go with the big block if it's a toy. If it's a driver go with the 351w. The 351w c/6 rack & pinion setup is not too tough to take.
Ah well, maybe next time.
Old Oct 6, 2007 | 09:20 PM
Mustang.'s Avatar
Mustang.
i want a street performer that will run like a scalded cat
Old Oct 6, 2007 | 09:38 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Why not a stroker based on the 460? The 385-series will handle a lot more power than the Windsor. The only reason I'd pick the Windsor is if you were looking for a road racer and needed the weight balance...and didn't have the budget for an aluminum block.
That said, good luck stuffing the 385 into the engine bay of a '68.
Old Oct 6, 2007 | 11:49 PM
Mr. Classic EFI's Avatar
Mr. Classic EFI
Stroker!
Never liked all the weight of an FE, in the front of a Mustang. Kills the handling.
Old Oct 6, 2007 | 11:55 PM
dcohen's Avatar
dcohen
id say go with the windsor
460 just seems like overkill in a 68
Old Oct 7, 2007 | 12:15 AM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
def 351w stroker, 460 way to damn big
Old Oct 7, 2007 | 12:16 AM
67mustang302's Avatar
67mustang302
For street the 351 would be better. You can get more parts that make streetable power for the Windsor for cheaper. Big block parts are ex-PENS-ive!! You can make more power than you can handle on the street with a 408, so why do it with a heavier engine? For an all out race application, a stroked 460 would be a complete Goliath, power out the wazoo!!!
Old Oct 7, 2007 | 05:01 AM
andrewmp6's Avatar
andrewmp6
im runing the man o war 460 which is a stroked 351w.unless your going to road race it get the 460 to cut back on the weight alum heads and intake help alot. if you get a aftermarket 460 block you can stroke it to a 806.
