4 to 5 Lug Conversion
Old Oct 9, 2007 | 02:57 PM
AscolA's Avatar
AscolA
Default 4 to 5 Lug Conversion
Hi there,
I have 68 coupe inline six that when I bought it was in the process of getting ready for a v8 conversion. I have the 5 lugs in the rear, but still have the 4 in the front. I had mentioned this before and many of you suggested upgrading to discs in front- which I plan on doing next spring. I just bought new rims and tires (5 lug) and can't wait to put them on. So my quesition is this.
Is there anyway to simply upgrade my front 4 lug set up to 5 lugs knowing that I'll be swaping my front drums for discs this spring?
Any advice or insite would be great.
thanks
Old Oct 9, 2007 | 03:22 PM
ford65stang's Avatar
ford65stang
Default RE: 4 to 5 Lug Conversion
Let me make sure this is clear
so in the spring you want to upgrade to disc brakes......but right now you want to change your 4 lug drum brakes....to 5 lug drum brakes so that you can run your new rims on all 4 tires....
the only way I think you can do this is to change your spindle to a v8 spindle....and then you would have to find some drum brakes off of a old mustang with the 5 lug pattern, and that should work.
Im not sure that a 5 lug drum setup off a v8 car willl fit with the inline six spindle.
FYI you would need a v8 spindle later anyway to upgrade to Disc brakes anyway
Old Oct 9, 2007 | 04:09 PM
TexasAxMan's Avatar
TexasAxMan
Since you have a '68, I think your spindles are the same as for a v8 car. That said, it still sounds like you are going to spend WAY more than you need to because you are making 2 conversions. Look at the kit at www.discbrakeswap.com for $525 you get it all.
Old Oct 9, 2007 | 04:25 PM
Shrinkdude's Avatar
Shrinkdude
Found this off a different forum.
65/66 6 cyl spindles are different from V8 spindles
67/68 6 cyl and V8 spindles are the same
The 6 cyl backing plates and drums are different
from the V8 versions on 65-68
Also
It breaks down like this in the MPC for replacement parts:
65/6: two spindles, I-6 and a V-8
67: one spindle, all engine/brake combos
68/69: drum spindle, same as 67, a disc spindle, a Boss 302 spindle and a Boss 429 spindle.
70-73: drum spindle, disc spindle
Old Oct 9, 2007 | 08:56 PM
andrewmp6's Avatar
andrewmp6
front you just need new hubs and brakes rear end http://www.perogie.com/Rears.htm for brakes http://www.mustangsteve.com/cobrabrakes.html the cobra brakes are pbr same thing as baer really is cheaper too but youll need 17s to clear them.
HRnB
GT350 S550 Tech
Dec 18, 2015 09:35 AM
Nov 10, 2015 11:39 AM
Oct 7, 2015 07:02 PM
DCole24
Sep 11, 2015 10:50 AM
