what is my cam
Old Oct 12, 2007 | 01:51 PM
eep4life's Avatar
eep4life
Default what is my cam
ok so i have another post going about my rockers and a lot of people are telling me if my cam is to much on the performance side than it will pull my studs out.... so my question is... is my cam basically just a stock replacement or is it to much for my pressed in studs
cam lift.... int = .280
exh = .295
valve lift.... int = .448
exh = .472
if you need more info ill see what else i can get...
thanks for all the help guys i would be lost with you..... oh yeah and its a 302
Old Oct 12, 2007 | 02:51 PM
Gary H's Avatar
Gary H
Default RE: what is my cam
Should be fine, thats not a whole lot more than stock.
Old Oct 12, 2007 | 09:31 PM
my77stang's Avatar
my77stang
your fine, and you should be ok with stock springs so long as their pressures are within spec for a stock spring
Old Oct 13, 2007 | 12:28 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Stock lift for a 302 ranged from .372 to .444 depending on the year (.444 for the pre-'72 versions). So, that cam will be okay. Since you're replacing the heads in the near future, just make sure your valve train stays tight. Mine pulled out with a .484 lift cam, FYI.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
