Carbon build up?
Old Oct 14, 2007 | 10:52 PM
dirtydave289's Avatar
dirtydave289
Default Carbon build up?
I have a 289 with some mild mods nothing super special and I heard somewhere that with an old engine like mine ('66) that it'll build up with carbon or something and stall on me if i don't give it a few good revs to clear it out periodically
is this true? does it clear on its own by me just driving or do i really need to rev to clear? or does it not even build up?
anyone who can educate me on this, THANKS!
Old Oct 14, 2007 | 11:08 PM
SmallBlockFloyd's Avatar
SmallBlockFloyd
Default RE: Carbon build up?
I've had a little experience with carbon build up, on rotary engines, and my experience with them, you would have to get higher rpm's than your casual cruise rpm's. If you still have the toploader behind it, just wind it up, on the highway in 3rd gear. Get it up to 4500-5000 rpm's for a bit or so.
Carbon will build up in any internal combustion engine, but it will also come out, with some high rpm usage. Just don't get a speeding ticket .
Old Oct 14, 2007 | 11:28 PM
dirtydave289
Hmmm sounds good..
any idea on how often the carbon will build up enough to cause me to stall?
i'll forget to get my rpm's up occasionally i'm sure...once i fire and warm her up will a few good revs clear me for a while?
Old Oct 14, 2007 | 11:29 PM
groho's Avatar
groho
I heard an ole wives-tail, that puttingwater into the carb, couple tablespoons at a time, while the car is running, making sure not to stall it, actually acts as an internal steam cleaner, and get's rid of carbon build up.
Old Oct 14, 2007 | 11:33 PM
dirtydave289
Sounds...somewhat legit
wonder if it works
Old Oct 14, 2007 | 11:44 PM
redhawkk's Avatar
redhawkk
To blow out the carbon, I'd take it out on the freeway, find a good long upgrade and put my foot to the floor. Probably best to first get up to a speed where it won't downshift when you do this. (No point over-stressing an old tranny...) This way you can get it putting out max power for 20 - 30 seconds without breaking the speed limit TOO much... (heh,heh...)....
Do this once in awhile and you should blow out all the carbon. Of course, if the engine is well-worn, there's always the risk of breaking something if you're pushing it to the max... Take your cell phone along in case you wind up needing a tow-truck.....!
Old Oct 14, 2007 | 11:52 PM
dirtydave289
Doesn't sound too bad
i can handle that
svfetter
Oct 5, 2015 11:39 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
mdg
Oct 1, 2015 07:04 AM
GLOCKer
Sep 28, 2015 07:36 AM
SYNY5TER
Sep 2, 2015 01:35 AM
