Differences in 69 & 70
Old Oct 15, 2007 | 02:11 AM
Manic Mechanic's Avatar
Manic Mechanic
Default Differences in 69 & 70
I have both a 69 Coupe and a 70 Coupe. They both need a lot of work and I am interested in where to find exact differences. This way I can decide what one to work on and what one to rob parts from.
Old Oct 15, 2007 | 02:47 AM
Bogalu's Avatar
Bogalu
Default RE: Differences in 69 & 70
Not much of a difference. I got a 69 so thats what I vote on.
Old Oct 15, 2007 | 02:59 AM
Manic Mechanic
I know there are not many changes but I need to know what parts I can and can't swap.
Old Oct 15, 2007 | 11:16 AM
middiepride's Avatar
middiepride
well, obviously the headlights are diff, 69 has 4 and 70 has two and that crossbar thing. ive heard that the 70 windows are a bolt in or something and they dont have a leak problem like the 69's potentially do. i like the 69 more personally but i thnk you can swap the windows if you're really set on the year. its a toss up really, the only noticeable difference i know is of the headlights, the rest is under the skin for lack of a better term
Old Oct 15, 2007 | 11:51 AM
boogerschnot's Avatar
boogerschnot
69 Has the 4 headlights up front and 70 only has the two in the grille.. I like the 69, of course..
Old Oct 15, 2007 | 12:21 PM
dnswwood's Avatar
dnswwood
Also the front fenders are different,the headlight buckets are different so they wont mate up right.When I bought my 70 I could never get the right fender to line up right,there was always a problem where the fender and bucket bolt together.When I took the car apart I found the problem ...a 69 fender with a 70 bucket crammed on it.
hope this helps
Jeff
PS as stated above the 69 windows glue into the track and the 70 bolts in.Somewhere on here there is a post on how to convert to the bolt in 70 windows.Ive heard lots of people complain about the windows coming unglued from the track.If you have a 69 and a 70 and choose to restore the 69 I would recomend putting the 70 windows in the 69.
Old Oct 15, 2007 | 12:39 PM
Hawkins 812's Avatar
Hawkins 812
Replacing the windows with the 70' bolt-in was my first project when i bought my 69'....easy fix.My cousin also had a 69' and his leaks every time it rains.
Old Oct 16, 2007 | 07:38 AM
73 Sportroof's Avatar
73 Sportroof
The tail lights are different and the '69 has side scoops ( low on coupes and high on fastbacks ).
Old Oct 16, 2007 | 06:00 PM
DanK69RustangVert's Avatar
DanK69RustangVert
Side marker lights
Fenders
Headlights
Tailights
Door glass and mounting (As mentioned, easy fix)
Steering column ('69 ignition in dash, '70 on column)
Side scoops on '69 not on '70
If 3 spoke rimblow steering wheel, they are different
Bucket seats ('69 has latch in the middle of the side, '70s are down low next to the seat bottom).
But you should be able to change either one from fenders forward for the other.
BTW - Early '69s were glue in glass, late model '69s started the bolt in like the '70s
Old Oct 16, 2007 | 06:13 PM
69mach1377's Avatar
69mach1377
Rob the 70...
Dokilar
15
Oct 16, 2015 08:13 PM
breaking
Oct 2, 2015 01:27 PM
UrS4
Sep 30, 2015 10:13 AM
mrappe
Sep 26, 2015 10:16 AM
