Going to look for new cam
Old Oct 15, 2007 | 11:39 PM
javier146's Avatar
javier146
Default Going to look for new cam
i will be going to look for a cam tommorrow, i saw this one on the comp cams website will this be a good cam for a stock 84 351w, only mods on it are performer intake, 4 barrel carb, and shorties hedman headers.
DESCRIPTION:
THUMPR™ for Small Block Ford Windsor
APPLICATIONCAMSHAFTS
VALVE SETTING
RPM
OPERATING
RANGE
CAMSHAFT PART NUMBER
CAM GRIND NUMBER
DURATION
VALVE LIFT @ 1.5:1
LOBE SEP. ANGLE
ADV.
@ .050”
IN.
EX.
IN.
EX.
IN.
EX.
IN.
EX.
HYDRAULIC ROLLER High performance street, stock converter ok, best with 2000+ converter and gears, choppy idle
Hyd
Hyd
1900-5600
35-600-8
283THR7
283
303
227
241
.531
.515
107°
*Notes:
1) Fits all Small Block Ford Windsor 1962-1995 that DID NOT
Old Oct 15, 2007 | 11:58 PM
Hawkins 812's Avatar
Hawkins 812
Default RE: Going to look for new cam
Is that the one "they" recomended ? Id suggest contacting Comp cams and either getting the whole kit or letting them decide the proper cam for your setup. From you describing your secondaries as a means to decide a proper cam makes me wonder if you know what your doing. [&:]
Old Oct 16, 2007 | 12:02 AM
67mustang302's Avatar
67mustang302
Kinda hard to tell what the specs are, it's kinda all over the place. Put some heads on that thing and it'll really come alive
Old Oct 16, 2007 | 12:14 AM
THUMPIN455's Avatar
THUMPIN455
Before you run out and buy a cam do me a favor and I will do a favor for you. Answer these questions honestly or to the best of your knowledge.
1: What type of driving do you intend to do? eg, street/strip, cruiser, drag car, weekend toy that needs a bit more oomph but a smooth idle..
2: Whats your budget for the cam and related valve train. A hydraulic roller will need lifters, pushrods, springs and distributor gear as a bare minumum. Read that as $$$$$ because your engine does not have the roller cam if its an 84 and all the parts must be retrofittted to it. A hydraulic flat tappet cam is the least expensive way to go.
3: Auto or stick?
4: If auto do you plan to swap in a higher stall converter?
5: What gears are in the rear end?
6: Does your car have AC right now?
7: will you be swapping to aftermarket aluminum heads any time soon?
8: Headers or iron manifolds?
9: Its a 65 right?
Old Oct 16, 2007 | 12:24 AM
javier146's Avatar
javier146
by me saying is this a good cam for me = me not knowing squat about cams, right now i do want a car with someoomf to it and right now i am looking for a decent cam $300 or less, it is a 65 with the ac not working, and no i do not have all the money to do all the mods needed for a thumper, in the summer time when i get back to working full time i would like to have it race ready, but for now just a fast street car.
Old Oct 16, 2007 | 12:27 AM
javier146's Avatar
javier146
headers are on their way and yes i will probably buy some aluminum heads later on but not in the near future.
Old Oct 16, 2007 | 12:33 AM
Hawkins 812
ORIGINAL: javier146
Your doing the right thing by coming on here and asking,rather than jumping into something you know nothing about. With THAT being said, i was trying to inform you that it would be a GREATidea to contact Comp cams and have them set something up for you. (http://www.compcams.com/DefaultWide.asp)
They are VERY nice people and work WITH you to achieve your goal.
CAM HELP®
1-800-999-0853
Hope this helps!
-Hawkins
Old Oct 16, 2007 | 08:43 AM
THUMPIN455's Avatar
THUMPIN455
x2 on the Comp Cams people. I like the cams they offer. Im running an XE274 flat tappet cam in my Cleveland, that would be a bit big for yours, since you have stock heads and it sounds like you dont want to buy springs, locks, retainers, and pushrods. So you would be looking for a cam that is somewhat smaller than that one, hydraulic flat tappet, that doesnt need the springs swapped to work. It is highly recomended you change the springs, locks, and retainers when you do a cam swap. Lifters on a non-roller cam are a definite must. If you use old lifters you will have a flat cam in less than an hour.
Now you dont have to buy from Summit, but here are some I would recomend to you.
http://store.summitracing.com/partde...p;autoview=sku
Old Oct 16, 2007 | 01:37 PM
javier146's Avatar
javier146
ordered a comp cam with .5 lift and valve springs, it will be a rough idle, and will run good on stock 351w engine for $269
Old Oct 16, 2007 | 01:42 PM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
thats the way a muscle car should be rough unrefined yet sophisticated and beautiful
GimpyHSHS
19
Dec 19, 2023 01:12 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
