toploader questions
Old Oct 16, 2007 | 07:01 PM
fenderleo's Avatar
fenderleo
Default toploader questions
are the 2.77 & the 3.03 3-speed trannys considered toploaders?
how can i tell the two trannys apart? serial #'s ?
Old Oct 16, 2007 | 07:15 PM
Cogtx's Avatar
Cogtx
Default RE: toploader questions
IIRC, both are considered toploader by design. The 2.77 does not have synchronized gears and was made prior to the 3.03 tranny. The 2.77 only came with the 170 and 200ci engines. The 3.03 came with inline 6 and V8. There should be an identification plate on the upper right extension housing attaching bolt (info from the 67 shop manual). The top three numbers should be the numbers you are looking for for ID purposes...hope this helps
Old Oct 16, 2007 | 08:20 PM
boss_dude_429's Avatar
boss_dude_429
and if you don't have a tag on the trans, i BIELIEVE that the number 3.03 or 2.77 stand for the length of the tail shaft, I'm not 100% percent but 90%
Old Oct 16, 2007 | 08:48 PM
Starfury's Avatar
Starfury
No, definitely not it, heh. The tail shaft is quite a bit longer than 3" I believe it's the input bearing diameter. Something like that.
Old Oct 27, 2007 | 09:38 PM
boss_dude_429
it has something to do with the tailshaft, mabey the lenght of it from the end of the housing, because i remeber reading it in an old statement the ford released to"inform" the public
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
