Changing oil pan gasket
Old Oct 19, 2007 | 01:26 PM
green_blurr's Avatar
green_blurr
Default Changing oil pan gasket
I walked into my shop yesterday and my engine was leaking oil all over the floor. turns out the drain plug is stripped so i am gonna replace it and the oil pan gasket and just get it out of the way . What type of rtv should i coat the oil pan with then place the cork gaskets over? i picked up a vicktor oil pan gasket set black rtv? grey? or orange? thanks
Old Oct 19, 2007 | 01:27 PM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
Default RE: Changing oil pan gasket
black
Old Oct 19, 2007 | 01:35 PM
RolandT3Speed's Avatar
RolandT3Speed
What he said.
Old Oct 19, 2007 | 01:36 PM
green_blurr
The guy i had put the engine together used orange could that be a reason why it leaks?
Old Oct 19, 2007 | 01:40 PM
USMCrebel's Avatar
USMCrebel
the only kind i have ever used is black.
Old Oct 19, 2007 | 02:27 PM
RolandT3Speed
Actually, for a pan gasket blue, black, or orange should be ok.
I believe the only difference is temperature range.
Old Oct 19, 2007 | 02:29 PM
jlg2002's Avatar
jlg2002
Color doesn't matter. the type matters! Choose a RTV with the specific application in mind (read the package). Most folks use black color. the important thing is that all is clean and dry during assembly, wipe off the excess if you can.
Old Oct 19, 2007 | 02:30 PM
boogerschnot's Avatar
boogerschnot
I used the red/orange stuff.. For everything..
Old Oct 19, 2007 | 02:32 PM
Starfury's Avatar
Starfury
I'd recommend The Right Stuff (quick drying and oil/fuel resistant), but generally any black RTV should work just fine.
Old Oct 19, 2007 | 02:42 PM
67mustang302's Avatar
67mustang302
Just use the Fel Pro 1 piece molded rubber with steel core gasket. Then you don't need sealant
