Battery
Old Feb 25, 2005 | 02:12 AM
guitarist88's Avatar
guitarist88
Default Battery
my battery dies on my 67. My friend says I could use his old one from his honda. Does it matter if the battery is different. or what would it do?
Old Feb 25, 2005 | 02:17 AM
rwcstang's Avatar
rwcstang
Default RE: Battery
yeah it does in a ways cuz some have different volts like ur friends think about it a honda right?? well the honda doesnt use that much power so it could be a low volt, as for your car if its a v-8 u would prolly need a big battery with a good amount of volts. i'd recommend optima batteries theyre pretty good. you could use ur friends battery but it would prolly drain it in a matter of time ur v-8 need tons amount of energy for it to run..
Old Feb 25, 2005 | 12:33 PM
horseshoeing's Avatar
horseshoeing
Default RE: Battery
different Amps. I say if you can hook it up and it turns the motor over, It would work.
Old Feb 25, 2005 | 05:31 PM
guitarist88
Default RE: Battery
I am probably going to get an optima. I just wanted to hool the other battery up to see if runs alright since i just put the carb. back on cuz i was rebuilding it. So it would be ok for a little bit until i get my nice battery?
michael
Old Feb 25, 2005 | 06:27 PM
Magiarn71's Avatar
Magiarn71
Default RE: Battery
Yeah, the amps are different, should still be 12 volts. It may work, may not. If it does, it may not work all the time. If you hook it up in a heated garage and it barely turns over, I wouldnt bring it anywhere on a cold day. As far as just to start it to see if it runs, I say go ahead and try.
BOB ROME
Jul 26, 2023 01:54 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
logan409
Sep 26, 2015 07:43 PM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
Art161
Sep 9, 2015 10:33 AM
