302 pulleys modification
Old Oct 27, 2007 | 01:21 PM
dankoziol's Avatar
dankoziol
Default 302 pulleys modification
I have installed the 302 from a 79 thunderbird in my "66. Sorry no choice it was missing the motor. I need your advice on the 3 pulleys to allowa one belt system to run the water pump and alternator. It has the 4 bolt hole crankshaft mounting. I'm not opposed to serpentine if that's the way to go. No A/C, no power steering.
Old Oct 27, 2007 | 03:29 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: 302 pulleys modification
Check out March for a pulley set. You could also find a 2-groove crank pulley to go with a 1-groove water pump pulley.
Old Oct 27, 2007 | 05:12 PM
Gary H's Avatar
Gary H
http://mustangsunlimited.com/itemdy0...atkey=emustang
You can also hit the wrecking yards, I think they switched to the 4-bolt balancer in '70
Old Oct 28, 2007 | 08:01 AM
deadcarnahans's Avatar
deadcarnahans
Junk yard items. The only issue is the radiator needs to have the lower hose barb relocated to the drivers side to match the water pump. The radiator shop can do this for you
[IMG]local://upfiles/36086/B20127F5352A47F9953EB378C3250B6B.jpg[/IMG]
Old Oct 28, 2007 | 01:16 PM
dankoziol's Avatar
dankoziol
In this photo. What year and engine did the crank and waterpump pulleys come from? I have the radiator switched and have all the other parts.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Galactic
Apr 29, 2019 02:56 PM
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
jaiidutch
Sep 14, 2015 10:29 AM
