POR 15
Old Oct 27, 2007 | 10:52 PM
hity645's Avatar
hity645
Default POR 15
We finally got my cars floor welded in, the next step is to find a frame shop and get minor work done and confirm the body is straight, then immediatly after get it media blasted. It will be garaged as long as possible, but Id like to get the engine, trunk and floor painted up with POR15. Browsing their website I see they have kits for the engine, floor and trunk. Anyone use these, or should I just get the 6 can kits and do small things. Painting the engine bay is not a priority and I can do that later. Thanks guys.
Old Oct 27, 2007 | 11:06 PM
4reboy's Avatar
4reboy
Default RE: POR 15
My body shop tells me that POR 15 is supposed to be used over rusted metal, not on fresh metal. I'm not sure if its in your best interest to cover teh floors, trunk, AND engine bay in POR 15, however people do it anyway.
Old Oct 28, 2007 | 03:44 AM
andrewmp6's Avatar
andrewmp6
Default RE: POR 15
Yes por15 works best over rust then clean metal por stands for paint over rust which it does nicely.Best thing i found for floor pans is spray on truck bed liners even the roll on ones work well.
Old Oct 28, 2007 | 04:02 AM
remicks's Avatar
remicks
Default RE: POR 15
+1 on spray on bed liners. But stay away from herculiner, it rubs off from normal wear and tear (friend's jeep, didn't last 6 months) and it doesn't do well with heat, gets gooey and slides off. Go with line-x or rhino liner. The best is line-x, its a sealant, its heat tested, blast tested by the USAF and stuff will slide and wash right off of it. I've seen the products side by side first hand and any day of the week I would take line-x for the few more dollars it costs.
Old Oct 28, 2007 | 06:43 AM
andrewmp6's Avatar
andrewmp6
Default RE: POR 15
I only used the roll on for inter fenders or on the back of anything fiberglass.
Old Oct 28, 2007 | 06:48 AM
fordoldies's Avatar
fordoldies
Default RE: POR 15
I also used bed liner for my undercarriage and on the inside of the car. I did have some come off when reworking the area. I ended spraying epoxy satin finish paint over the bed liner paint with good results.
Old Oct 29, 2007 | 09:54 AM
TexasAxMan's Avatar
TexasAxMan
Default RE: POR 15
Where do you get the bedliner material? AutoZone?
Old Oct 29, 2007 | 02:29 PM
gbryning's Avatar
gbryning
Default RE: POR 15
Before you use POR-15 you might want to look at Eastwoods rust Encapsulator.
(no I don't work for them), I have a PDF of an article in Auto Restorer magazine where they did a test on both side by side, the Eastwood stuff won hands down. Let me know, and I can send you a copy.
gbryning@comcast.net
Old Oct 29, 2007 | 02:31 PM
Hawkins 812's Avatar
Hawkins 812
Default RE: POR 15
ORIGINAL: TexasAxMan
Napa, AutoZone, Advanced Auto, etc.....Neither of them had it stock around here, but NAPA ordered it for me.
Old Oct 29, 2007 | 03:15 PM
dozierstang's Avatar
dozierstang
Default RE: POR 15
+1 on Rust Encapsulator. That stuff sticks good to any condition metal. And you can top coat with your choice of toppings. Also, Napa and Advanced is where I got my spray on bedliner. Good stuff too. I think it is made by Dupli-Color.
