289 Engine rebuild
Old Oct 31, 2007 | 05:28 PM
fweidner's Avatar
fweidner
Default 289 Engine rebuild
I will be rebuilding my 289 this winter, Any recommendations on the cam and heads? Is it worth it to switch to 4 valve heads? Currently it is a 289 C code. Will be changing the carb to a 4 barrel with alum.intake manifold.
thanks,
Fred
Old Oct 31, 2007 | 05:35 PM
JohnCalvin's Avatar
JohnCalvin
Default RE: 289 Engine rebuild
4V heads?
Old Oct 31, 2007 | 05:49 PM
dcohen's Avatar
dcohen
afr 165 cc heads
never heard of a 4v head on a 289, not sure its possible
Old Oct 31, 2007 | 06:47 PM
DriWashSolutions's Avatar
DriWashSolutions
...or early 289 heads (1964) if you can find -'em. They flow a little better since they lack the hump in the exhaust port.
Old Oct 31, 2007 | 07:18 PM
Mustangdemon67's Avatar
Mustangdemon67
edelbrock sells a pretty nice kit, includes cam cylinder heads rpm air gap and timing chain. thats what i would go with.
Old Oct 31, 2007 | 07:49 PM
Starfury's Avatar
Starfury
I think you're thinking of 4V heads, in which case the V means venturi (as in carburetor), not valve. But there is no difference between the 2V and 4V heads, or and even the K code hi-po heads use the same port castings.
AFR's are generally regarded as about as good as you're going to get on a street engine, but they do cost a little more. Edelbrock also makes some very good heads, or you could even go with some Windsor Jr's if you wanted to stick with cast iron.
Cam is dependent upon a lot of other variables. What kind of driving do you do? What gears and tranny are you running (or planning to run)? Which heads are you going to use? Can you put up with a lopey idle for more top-end power?
Old Jan 26, 2009 | 03:49 PM
andrew340's Avatar
andrew340
is the 289 4 barrel and 2 barrel engine's the same other than the intake and carb?
Old Jan 26, 2009 | 05:03 PM
fast66's Avatar
fast66
According to my spec books, between the C and A code engines there was a slight compression ratio difference, a slight cam difference, the dizzy was tuned for advance slightly differently, and thats about it. If you are doing a full rebuild, non of this is of any consequence to you at all.
Work out what you want from the car, ie daily driving or steet weapon etc, how much highway driving you expect to do, are you going to take it to the track, auto or manual, want original looks, all of these thing need to be thought about, and they will drive what sort of engine you will need to build.
Cheers
Nick Oliver
Oct 17, 2018 04:22 AM
TfcCDR
Sep 14, 2015 12:08 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
Brian Emmer
Sep 9, 2015 02:50 PM
