Steering wheel removal
Old Nov 2, 2007 | 11:45 AM
scuf23's Avatar
scuf23
Default Steering wheel removal
Well - I am decided to install my rack and pinion today
Got the original steering linkage removed
Trying to remove the steering wheel and it is not going anywhere right now - HELP!
- I removed the horn button
- Removed the nut holding the wheel to the column
- Removed the turn signal indicator
- Removed small philips screws
I pull and it is not coming - did I forget something?
Thanks
Old Nov 2, 2007 | 11:57 AM
blane17's Avatar
blane17
Default RE: Steering wheel removal
yeah.. the steering wheel puller. autozone has them... they are cheap
Old Nov 2, 2007 | 12:18 PM
scuf23's Avatar
scuf23
Wish I had known that before .... anyway I am going to run to autozone right now
Thanks
Old Nov 2, 2007 | 12:48 PM
blane17's Avatar
blane17
sometimes they come off with just a little pulling, but lot of times u need the puller
Old Nov 2, 2007 | 12:57 PM
19coupe65's Avatar
19coupe65
get the puller, easier
Old Nov 2, 2007 | 03:48 PM
scuf23's Avatar
scuf23
Bought the puller came out in like...uh .... 2 seconds! I couldn't believe it! Good thing done
Also got the steering box and shaft out - I did not follow exactly the instruction ... I did not feel like removing the engine mount so I just cut the steering shaft while still in place ... I made sure it would still be long enought for my rack and pinion set up ... hopefully will be done sometime tomorrow so I can get teh alignment done and have some fun!
BOBCATJACK
Sep 14, 2015 02:18 AM
wawagner82
Sep 13, 2015 09:02 AM
Sep 10, 2015 08:39 PM
Sep 8, 2015 11:50 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
