replace drum brakes with disc
Old Nov 8, 2007 | 03:29 PM
mrjohn914's Avatar
mrjohn914
Default replace drum brakes with disc
i have a 1968 stock mustang 289. i am thinking or putting disc in the rear and front. but the price of the kits are way to expensive. is there a certain year of mustang with disc brakes that will fit my year of car. i was thinking of finding used parts to build my disc brakes................
any ideas or information will help...........
Thank you............. john
Old Nov 8, 2007 | 03:38 PM
mySAVIOReigns's Avatar
mySAVIOReigns
Default RE: replace drum brakes with disc
If it's got a stock 289, it has stock front discs. There are lots of things for the rear end, but I don't know any off the top of my head. Look in the FAQ or do a search for "rear-end swap"
Oh, and welcome to the forums!
Old Nov 8, 2007 | 04:15 PM
RolandT3Speed's Avatar
RolandT3Speed
I did the Granada swap for the front.
Cost about $400 total. Make sure you get the distribution block from the donor car.
Old Nov 8, 2007 | 04:22 PM
cmanf's Avatar
cmanf
"If it's got a stock 289, it has stock front discs. "
What have you been smoking? lol
Mine is was stock 66 289 with drums on the front.
Checked the codes it came that way.
Old Nov 8, 2007 | 04:23 PM
TexasAxMan's Avatar
TexasAxMan
www.discbrakeswap.com has a kit for $525 that has everything you need.
Old Nov 8, 2007 | 04:25 PM
cmanf's Avatar
cmanf
These guys arent too bad I have the front kit and master cylinder.
http://www.rcmotorsports.net/
Old Nov 8, 2007 | 04:27 PM
TexasAxMan's Avatar
TexasAxMan
Yeah, but they advertise one price and charge another.
Old Nov 8, 2007 | 04:35 PM
mySAVIOReigns
ORIGINAL: cmanf
Really? ha, I'm sorry. I thought they were. I think I got crossed with the 5-lug thing...
I recommend www.discbrakeswap.com as TexasAxMan mentioned above. Dennis is a great guy and really helps out. His price is awesome, and his directions are fantastic.
Old Nov 8, 2007 | 05:10 PM
okiedragster's Avatar
okiedragster
well i did something a lil different for rear disc on my 71, i went to a swap meet one year and found a 8.8 rearend (complete) out of a 85 lincoln versailles that had disc's and i bought it for 75.00 took it back to the shop andtook some measurements and cut the ends of the axle tubes off just infront of the caliper brackets so i could get the full bracket off without cutting into it, i then bolted the rotors on my axles and put the calipers on and squeezed the caliper on the rotor and the caliper bracket lined right up on my axle tube and i then welded it to my axle tube and it looks factory. everytime someone sees the rear brake now they ask if it came on my car from the factory...lol
Old Nov 8, 2007 | 05:17 PM
cmanf's Avatar
cmanf
"Yeah, but they advertise one price and charge another."
Man ive never had the problem with those guys.
Then again I call them a lot too they have helped me out so much.
William Found me the right oil pan for my setup and gave me the part # for Canton and told me to call them to get it cheaper than he could sell it for.
I wouldnt right them off check them out at shows you wont find better guys.
