Low enough?
Old Nov 13, 2007 | 05:41 PM
tarafied1's Avatar
tarafied1
Default RE: Low enough?
Why don't you like the blocks? I've had the springs on the car a while, I don't know if anyone would want to swap used springs.
Old Nov 13, 2007 | 05:49 PM
Deviousfred's Avatar
Deviousfred
well, under very heavy loads(acceleration) they are not the best thing to have. You hear a lot about them in the 4X4 scene where lifting blocks are frowned upon. I guess its not as solid as if the diff was mounted directly to the springs. I dunno that a 2"-3" block would have such a bad impact but personally I would prefer the springs.
Old Nov 13, 2007 | 06:17 PM
6marc5's Avatar
6marc5
Your car is looking sharp! I like the shelby tail light panel and the decklid tail. I thinkI would drop the assend 2 or 3 inches or so. Enough to lower it noticibly but high enough so it still has a little bit of a rake to it. Anyways,car is looking great.
tarafied1's Avatar
tarafied1
How much would a reverse eye spring lower the rear? I prefer a stiff spring as I do haul my 3 boys in the back seat...
Old Nov 13, 2007 | 06:22 PM
Deviousfred
Well, you could go with a 5 or 5 1/2 leaf spring with a reverse eye from Mustangs Plus it'll run you about $240
Old Nov 13, 2007 | 06:48 PM
Sxynerd's Avatar
Sxynerd
Wow, your car looks really good. I'd lower the back so it aprears to be leaning forward just slightly. It looks good at shows, plus while driving it will even out and look 100% level.... Which is badass
Old Nov 13, 2007 | 08:32 PM
390bigblock1's Avatar
390bigblock1
ORIGINAL: tarafied1
if you lower the rear you have to lower the front more too, but it think it looks good in my opinion.
Old Nov 13, 2007 | 09:22 PM
1970coupe's Avatar
1970coupe
omg! im in love. this has to be one of the best looking restomod coupes ive seen in a while. god your lucky to own such a beaut
Old Nov 13, 2007 | 09:57 PM
baddog671's Avatar
baddog671
Tara, I put mideye 5-leafs on my 67 and was alittle shocked at how much it lowered it. I expected a noticable difference, but not that much. And, since they say replacing your saggy springs with standard will actually lift the car, i figured a mideye would leave it about the same level. I can only imagine reverse-eye, it would probably be laying on the tire...
I have 225/70/15's on the rear now but my rear end is also about 200 pounds lighter than it should be, so it'll be even lower soon. I'll try to get you a picture. They stick out alittle too far becuase of incorrect spacing, but I think it looks beastly.
Nic
Old Nov 13, 2007 | 10:15 PM
tarafied1's Avatar
tarafied1
ORIGINAL: 1970coupe
Thanks, it's been a long project. I have been working on it 17 years. It has changed a lot but it's the closest it's ever been to looking like something other than a pile of parts in the garage.
